LED interior light kit for 2010-2012 Prius
Discussion in 'Gen 3 Prius Accessories and Modifications' started by -1-, Feb 17, 2013.
  1. ES44AC
    ES44AC C.A.U.S
    319
    77
    Yeah they are, but God help you if you have one LED on a panel burn out and you ask for warranty. Prepare to put your " jump through hoops" shoes on. Don't for a minute think they will take your word for the problem or even if you send a photo, they want the panel back so they can 'examine and test' it..... before they hopefully send a replacement.
    Trust me I know, I am hoop jumping now.........<siah>
  2. Sfcyclist
    Sfcyclist Senior Member
    1,621
    376
    SF, CA
    I'm mainly interested in the one for the trunk. How bright is the LED in this kit for that? How many SMD's are on there for that application? thanks
    ES44AC likes this.
  3. Totmacher
    Totmacher Honey Badger don't give a carp
    301
    110
    Mission Viejo, CA
    I'm impressed that place in China I got the set off ebay for 25$ from has already got the item to LA per the tracking number... Not bad 5 days china to LA and guessing another 1-2 to get to me.
  4. ES44AC
    ES44AC C.A.U.S
    319
    77
    HIya SFcyclist,
    The one for the trunk is a small panel about 1 1/4: square that has 6 leds on it. The panel simply attaches to the inside of the trunk light lens. It's not going to blind you but it's OK.
    Note: Prior to spending too much on the JDM kit I had a single "festoon type" one piece LED bulb in there. It too had 6 leds on it but they were very close to each other. The color was the same as the JDM ones, this bulb came from "superbrightleds dot com"
    hope this helps
    ES44AC
  5. Sfcyclist
    1,621
    376
    SF, CA
    So brighter than stock bulb?
  6. detroit11
    detroit11 Junior Member
    I got the JDM kit. the trunk bulb is brighter than stock.
  7. 4everS2K
    4everS2K Junior Member
    23
    Los Angeles
    LEDs above the headlights and plate light LEDs are all fried!!! I thought it was the blown fuse but found out that all four LEDs gone bad. At least all the interior LEDs are still fine. Did anyone here replace the exterior bulbs with LEDs? If yes, are they still working fine? Btw, I replaced them a month ago.
    Bullet Salvador likes this.
  8. Bullet Salvador
    109
    44
    Los Angeles
    So far my LEDs are holding up. What kind did you get (possible photo) and where did you get them?
    Sorry about your unfortunate disaster. =\
  9. 4everS2K
    23
    Los Angeles
  10. ockevin
    ockevin Active Member
    493
    148
    Orange County
    My led's are all working perfect. I got them from Alex @ Fuzion Teknique.
  11. ES44AC
    ES44AC C.A.U.S
    319
    77
    Ditto all mine both exterior and interior are fine. Got 'em from iJDMTOY.
    I did have a failure of one of the leds on the panel for the vanity mirror lights, one of the many on the panel quit after it was powered off and on 3 times. Got it replaced no problem, under warranty,
    ES44AC
  12. Bullet Salvador
    109
    44
    Los Angeles
    wotcher likes this.
  13. 4everS2K
    23
    Los Angeles
    Do you have a link to that item? I just couldn't it on Ebay somehow.
    Thanks!
  14. Bullet Salvador
    109
    44
    Los Angeles
    wotcher likes this.
  15. 4everS2K
    23
    Los Angeles
  16. Sassylady
    Sassylady Junior Member
    26
    Birmingham, Alabama
    I bought these lights, same seller on e-Bay for less than $22 free shipping. The link is now updated to the correct price. It does NOT include license plate lights. It took 15 days to get them from China. They are bright white lights of moderate brightness. One of the lights was missing from the package and I am waiting for them to send it. There is a minimal language barrier, as you can see from the feedback on ebay on their negative responses. My emails with them were somewhat difficult in that they say the same thing several times back and forth and don't really answer the question the first several times. Eventually I am getting the answer. If you are like me, not too familiar with installing LED's in cars, you don't know which light goes where when you get them and there is no part number to go by on the lights to match to the sales list. I emailed them and they said they sent instructions. Their instructions consisted of 3 words "Take off cover". That didn't help me tell which light was which. Finally they sent pictures and labels of 3 of the lights they sent and from the pictures I was able to determine what lights went where and it helped me determine which light was missing....I couldn't tell them what light was missing (rear dome light) until I determined which lights they sent... Additionally, the light they sent for the trunk area does not fit my Prius. I suspect it would be the same size for the missing back dome light, and if so, that wont' fit either. I have emailed and asked for lights for those two areas of less than 31 mm. I have since become aware than I need a 29mm light - so they are sending the spring loaded collapsable lights (28mm - 43mm) and that should work. The Good seller, just be patient when dealing with them if there is a problem. They are very responsive to your emails.
  17. quickbike
    quickbike Member
    39
    26
    Sacramento, California
  18. mrbigh
    3,686
    699
    Long Island, NY
    Do they still manage the "Theater effect" ? Slowly dimming?
  19. ny_rob
    ny_rob Senior Member
    1,968
    813
    L.I.- NY
    I have similar LEDS to ones from the ebay link above your post.. and they still dim/fade to black when turning off.
    BTW- did you get your 50 watt HID's yet?
  20. mrbigh
    3,686
    699
    Long Island, NY
    YES !! :) ....these will go in on Sunday, I had to order the relay kit too. I was short on parts.
    Seems that October is "Prius lighting upgrade month".
