Led Light strips
Discussion in 'Gen 3 Prius Main Forum' started by Taxi/Limo, Mar 6, 2020.
  1. Taxi/Limo
    Taxi/Limo Active Member
    526
    107
    This is not a Prius question but I am hoping someone here has some experience with 12 volt led strips
    I bought an LED strip at the auto parts store to put in my top light (taxi) and I can't make it work with my car's 12 volt system in fact I can't make it work at all on any battery
  2. spiralhelix
    spiralhelix Active Member
    255
    220
    Illinois
    Maybe some more info on which strip you bought? Is it possible you got and extension and not a starter?
    -Spiral
  3. Taxi/Limo
    526
    107
    They are called LED GLOZ made by Alpena they came with a little mini battery built in to the packaging so you can see how bright they are
    So I don't don't if that means they are a starter or what
    I think there must be some way to hook them up
  4. Grit
    Grit Senior Member
    6,577
    4,230
    Wilkes Land
    Check polarity, if correct, check power leads if they're live.
  5. Taxi/Limo
    526
    107
    I do have a tester but not sure how to do all that
    I can probably figure it out
    I checked for continuity on the strip and there was none
    #5 Taxi/Limo, Mar 6, 2020
  6. Taxi/Limo
    526
    107
    I figured it out
    I did not know there are two separate strings of four each lights and they have to be connected separately
    I was thinking they were all one string
    Thanks guys for responding
