LED Light Upgrades for 2022 XLE
Discussion in 'Gen 4 Prius Main Forum' started by TheWhiteWedge, Nov 22, 2022.
  1. TheWhiteWedge
    TheWhiteWedge New Member
    17
    2022 Prius
    Hello All,
    I recently became the owner of a 2022 Prius XLE and although I love this vehicle, I'm not a huge fan of the halogen turn signal and reverse lights, and am wondering if you all have any suggestions for replacements? (or if you even recommended replacing them).
    Also, any suggestions for the trunk light? It's very dim and nearly pointless to have. Thanks!
  2. Diemaster
    Diemaster Active Member
    302
    265
    so. cal
    I always use Superbrightleds or M4. Just get the brightest ones they have for your bulb style as some of them are barley brighter than a stock bulb. Make sure the bulb color is the same as the lens color; get red for a red lens for example. Also for the turn signals, you need to install power resistors to keep the flash rate the same. You can get CAN LED bulbs that have this resistor built in.
    If you want REALY bright reverse lights (assuming it's a 921 bulb) get these. I have these in my Prime and love them, especially at night.
  3. TheWhiteWedge
    17
    2022 Prius
    Thank you very much for your advice!
