LED Lightbar on a 2008 prius
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Acidbass32, Mar 8, 2015.
  1. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
  2. Acidbass32
    Acidbass32 Member
    217
    53
    Galveston, TX
  3. red07gen2
    red07gen2 Junior Member
    71
    The South
    i am soo ordering one to go in my lower grill area
  4. JJsCarAudio101
    JJsCarAudio101 New Member
    17
    Los Angeles CA
    Yes LED strip bars are the way to now, untill a new andbetter product is made. I have installed many LED bars and I prefer them over halogen/fog lights.
  5. red07gen2
    71
    The South
    put an inexpensive 24" led bar on my truck's front bumper and it overpowers the fogs and the hids ...best high beams i could ever install
  6. gardson
    gardson Junior Member
    SC
    Any update? I'm thinking of putting a LED bar on my Prius as well.
  7. red07gen2
    71
    The South
    ordered a 21" bar with mounts 24" should be in on friday
  8. Acidbass32
    Acidbass32 Member
    217
    53
    Galveston, TX
    I ordered my 20" Cree combo beam light bar and a laser switch, hopefully it'll be here after finals and I can have a nice little project after the stress.
  9. red07gen2
    71
    The South
    mine arrived today .....going to run to the hardware store and get mounting bolts tomorrow and a lawn mower belt ...broke 1st one in 2 years
  10. Acidbass32
    Acidbass32 Member
    217
    53
    Galveston, TX
    how do you plan on mounting it. I want mine behind the grill but finding a suitable mounting point is proving to be kinda difficult being that the radiator is right there and the anti-drag plates are not really stable enough to mount a light bar on.
  11. red07gen2
    71
    The South
    I am going for a below the bumper install ....thinking of putting it in the lower grill area
    and removing the factory fogs and center grill (one one works anyway )
  12. Acidbass32
    Acidbass32 Member
    217
    53
    Galveston, TX
    I'm going to play around with placement I guess to see how everything works together. did you get a single or double lead switch for yours? I ordered a single lead because I used those on my truck but I'm not sure about the power draw.
  13. red07gen2
    71
    The South
    iwas just going to unplug the broken OEM foglights and use the same power lead to hook up my lightbar
    literately plug into one of the fog light plugs the way i figure it the stock foglights draw a heck of a lot more power than those leds do
    the bar only pulls 8 amps
  14. xliderider
    xliderider Senior Member
    8,140
    3,276
    Honolulu, HI
    The stock foglights draw about 4.5 amps each, so putting an 8 amp draw from your light bar on the wiring from one foglight might be a problem.
    I'd put it on a relay, you can use the original foglight wiring harness to trigger the relay, but take the power for the light bar from the fuse box.
  15. red07gen2
    71
    The South
    good idea thanks for that ...
    better safe than sorry
  16. Acidbass32
    Acidbass32 Member
    217
    53
    Galveston, TX
    So here is the update on the lightbar. I installed the lighted switch and made sure that was functional (light bar will be in tomorrow), being that this rocker switch has an LED in the switch it does stay on even when the car is turned off because it is hooked directly to the jump site at the front of the vehicle. It is a single LED so I cant imagine that it will drain the battery, but am I wrong?
  17. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
    Will it drain it, yes. How long will it take?...quite a while depending on the health of your 12v and long the car is off.
    Lets see some pix of the finished install!
  18. Acidbass32
    Acidbass32 Member
    217
    53
    Galveston, TX
    So mind you I still am cleaning up the wiring and the light bar won't be attached until tomorrow (when fedex decides to deliver), and it's really sunny in Texas today so the rocker switch isn't as bright. However this is what I have so far
  19. red07gen2
    71
    The South
    i am going the other way .....lightbar installed but not installed the wiring yet ...
    where did you grab the 12v only while the car is on wire from......behind the radio?
    I am tapping into the fog light wire through a relay and find a constant 12v and ground under the hood
  20. red07gen2
    71
    The South
    still need to put the grills back on ....had to order new ones the ones on the car were busted all up also once I pulled the bumper off SURPRISE aftermarket bumper ..
    #40 red07gen2, May 5, 2015
    Justdidit likes this.
