LED lights
Discussion in 'Prius v Main Forum' started by Slask7, Sep 18, 2012.
  1. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    I put a pair on my Omni 20 years ago. The lens combined with the height-shield were a remarkable improvement over the lights of the time. Having seen that, I was suprised it took so darn long for them to catch on as standard headlights.
  2. Slask7
    Slask7 Junior Member
    Just got a quote for Toyota, 1295 per light to replace it.
    Galaxy Nexus ? 2
  3. gti303
    gti303 Junior Member
    22
    HOLY! Now I regret ordering that trim...hopefully they do last the liftime of the car
  4. Slask7
    Do you notice any advantage to self leveling headlights?
    Galaxy Nexus ? 2
  5. gti303
    22
    are you asking me? I haven't picked mine up yet :(
  6. stearicom
    stearicom Member
    81
    26
    The auto leveling is a great feature. It adjusts with the load in your car so you do not glare oncoming traffic. The more weight you put in the car the rear end goes down. So, the front end of the car is angled more up. The headlights then angled more up causing glare.
  7. Slask7
    Just to clarify the entire unit cost 1295 and it's about 200 per bulb.
    Galaxy Nexus ? 2
  8. SCRWGas5
    SCRWGas5 New Member
    156
    Charlotte, North Carolina
    Any exerience with signal LED bulbs?
    Today I got some more LED bulbs. Two white bright ones for reverse which looks great. Got two amber ones for the rear sigal lights. However I haven't gotten my relay thingie yet for the hyper flashing. My concern is I wonder if the bulbs aren't working. I tried plugging them both in one side, both poles tried. When I hit the flasher on that side I get the hyper flashing front light and nada on the new bulb. Just off. I swapped the poles, tried the other bulb. Still nada. Does the bulb need the relay in order to work at all? Or do I have two DOA bulbs?? Also of note, when I put on the hazard lights, the three working original bulbs blink at correct speed. Just isn't what I expected. Should I wait and try again after the relay comes or should I assume I got two duds?
    Read more: http://priuschat.com/threads/what-did-you-do-to-ur-prius-today.112616/page-20#ixzz27bpLITQe
  9. Tideland Prius
    16,678
    I have no experience with signal LED bulbs. How long til the relay comes? Do the signal bulbs work in another location so that you can test it out further? (e.g. they fit the reverse light location.. I don't remember what the number of the bulb base is)
