LED lights
Discussion in 'Gen 3 Prius Accessories and Modifications' started by MPGnutcase, Aug 23, 2015.
  1. MPGnutcase
    MPGnutcase Active Member
    579
    114
    Chicago
    Ok-- has anyone replaced all the lights inside and out with LED's ?? looking for info please
  2. SubCode
    SubCode Senior Member
    728
    1,328
    yes....and using the search feature on the website...you will find..tons of posts
    about it...so you come to the right place..
  3. Vman455
    Vman455 Senior Member
    517
    532
    Champaign, IL
    Yep, shortly after I bought the car a year and a half ago. Here's the list I made when I bought everything:
    Front turn signals: 7443 amber (18HP-LED, $35.90/pair; superbrightleds.com)
    Parking lights: 194 (WLED-WHP5, $11.90/pair; superbrightleds.com)
    Front side marker: 194 (WLED-AHP5, $11.90/pair; superbrightleds.com)
    Rear turn signals: 7443 amber (18HP-LED, $35.90/pair; superbrightleds.com)
    Reverse lights: 7443 white (18HP-LED, $35.90/pair; superbrightleds.com)
    License plate lights: 194 (WLED-WHP5, $11.90/pair; superbrightleds.com)
    Map lights: 194 (10 SMD LED, $19.90; superbrightleds.com)
    Dome light: 3175 (4 SMD LED, $6.95; superbrightleds.com)
    Hatch light: 3175 (4 SMD LED, $6.95; superbrightleds.com)
    Step lights: 194 (WLED-WHP5, $11.90/pair; superbrightleds.com)
    Vanity lights: 194 (WLED-WHP5, $11.90/pair; superbrightleds.com)
    Prices may have changed since then. The only bulb I couldn't get to work was the hatch light; for some reason, the replacement LED festoon bulb wouldn't fit securely in the clasps. Also, I might look for something a little brighter for the reverse lights and turn signals.
    One other thing: for the turn signals, you will need to get an electronic flasher relay to replace the stock flasher. It's in the dash behind the steering wheel, and you can find it by listening; put the steering wheel in its lowest position and look through the gap on top and you'll be able to see the flasher, then just reach your hand up behind until you can get hold of it.
  4. MPGnutcase
    579
    114
    Chicago
    thanks for the info
  5. kenichols29
    kenichols29 Active Member
    250
    109
    Mckinney, Texas
    I was planning to start doing interior leds too. Does anyone know how to replace the the door step light?
  6. Starbrand
    Starbrand Senior Member
    493
    1,500
    Westmont, IL
    fast forward to 2:50. hope this helps.
  7. el Crucero
    el Crucero Senior Member
    1,628
    692
    Inland Empire
    WHAT are those wheel covers on the Prius in your avatar? Where did you get them? Cool, I like them!
  8. MPGnutcase
    579
    114
    Chicago
    Thanks
  9. MPGnutcase
    579
    114
    Chicago
    Mouse over image to zoom
Loading...
