LED on electronic key
Discussion in 'Gen 3 Prius Technical Discussion' started by Maj, Oct 29, 2013.
  1. Maj
    Maj Junior Member
    Orlando, FL
    Newbie here with a 2010 Prius IV. The LED on the electronic key blinks at seemingly random times. Whats the scoop?
  2. gliderman
    gliderman Active Member
    751
    225
    What LED? Where on the electronic key? Do you mean the key FOB?
  3. ReDave
    ReDave Member
    82
    25
    Central California, Sierra/Sequoia Foothills
    2019 Prius Prime
    does it blink more when in the car?
  4. Maj
    Maj Junior Member
    Orlando, FL
    Yes, the rectangular plastic fob with the lock/unlock buttons. The LED is just above and to the left of the lock button.
  5. Maj
    Maj Junior Member
    Orlando, FL
    I first noticed it when I was showing the car to some friends while walking around the outside. Then I noticed it again today when I pulled in the garage while inside the vehicle in park.
  6. gliderman
    751
    225
    I had never noticed. 75k miles and 4 yrs and I never saw it til you pointed it out.
  7. rdgrimes
    rdgrimes Senior Member
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    It should blink every few seconds when its in communication with the car. I think it may also blink when you push any buttons on it.
  8. RobH
    RobH Senior Member
    2,385
    991
    70
    Sunnyvale, California
    And it stops blinking at all when the battery is about to die...
  9. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Communicating with the mother-ship...
    Priusmpg likes this.
  10. longshot
    longshot Junior Member
    84
    16
    Wonder if it keeps blinking if u leave your keys in the car overnight. I leave mine in my car because it is parked inside. Notice it blinking also.
    SPH-L710 ?
  11. David Beale
    David Beale Senior Member
    5,963
    1,990
    Edmonton Alberta
    From the writings of the Prophets (the owners manual) -
    "●As the electronic key always receives radio waves, the battery will
    become depleted even if the electronic key is not used. The following
    symptoms indicate that the electronic key battery may be depleted.
    Replace the battery when necessary. (→P. 454)
    • The smart key system or the wireless remote control does not operate.
    • The detection area becomes smaller.
    • The LED indicator on the key surface does not turn on."
    RTFM? ;)
  12. El Dobro
    El Dobro A Member
    7,102
    3,282
    The transmitter LED blinks when it's around the car to let you know it's in range.
