1. PRIUS STAR SHIP
    PRIUS STAR SHIP Junior Member
    34
    17
    I'm planning to upgrade my stock H11 low beam bulbs with these, wanted to know if anyone had any experience with them or any other similar types of kits.
    24 Watt CREE LED Headlight Kit (CANBUS Compatible) SECOND GENERATION
    Thank you for your opinions and suggestions.
    2010 Prius 4 with 65K miles.
    Use Kendall 0w-20 Full Synthetic.
    Other LED bulbs on my Prius is Lumen, purchased at CarId.com
    Priusmpg likes this.
  2. Priusmpg
    Priusmpg Active Member
    628
    108
    Fremont, California
    2014 Prius Plug-in
    They seem nice, please tell us when you do install them with pics of night and ground shadow
    iPhone ? - now Free
  3. ataylor2
    ataylor2 Member
    122
    East San Francisco Bay Area, CA
    Looks like they would probably work better in a reflector than they would in a projector. I think its pretty safe to say if it needs those fans, its going to fail at some point especially if there is no fan warning system.
    Would be nice to see some shots of the beam.
  4. -1-
    -1- Don
    1,254
    439
    Chester, Virginia
    2024 Prius Prime
    :) Will be interesting to see how they work out. Can't imagine the LEDs would produce much heat, if any. What's the price for the pair? I have the factory LEDs headlights on my PIPA. Really like the light output and I don't notice any draw on my EV mileage.
  5. fuzzy1
    10,647
    Even LEDs put out heat. Though they put out much less heat then incandescents of similar luminosity, they are also much less tolerant of high junction temperatures and poor thermal design.
    A 24 watt lamp of any technology should have a heat output approximately equal to 24 watts minus the actual photon power of its light output. For an incandescent, that might be 21-23 watts of heat. For an LED with today's technology, that is likely be in the range of 12-18 watts.
  6. edwardjd
    edwardjd Junior Member
    Federal Way, WA
    Here's is the info on the web site given by PRIUS START SHIP:
    RRP:
    $299.95
    Your Price: $239.95 (You save $60.00)
    SKU:24-Watt-LEDK
    Shipping:Calculated at checkout
    Product Description
    Never Change Your Headlight Bulbs Again. LED Kits Are Guaranteed For The Life!
    You are looking at the future of headlight lighting. Gone are the days of halogens, and HIDs are super bright but are prone to issues on newer vehicles and are rated to burn about 3,000 hours. Introducing the second generation Lumatron Superior LED headlight kits! Our LED headlight kit far surpasses HID kits in brightness. There's no warm up time, instant on!
    The Lumatron 24 watt LED headlight kit is only produced in H4,H7, H11, H8, 9005, 9006, H4-3 (High / Low Beam) bulb sizes, and produces a vibrant 6000k pure white light. This LED headlight kit includes military vehicle standards for heat dissipation on the ballasts.
    It comes with 2 ballasts, and 2 fans, as well as all wiring needed for a plug and play setup (which is only a few simple connectors)
    And Remember it is Covered by a Lifetime warranty! You will never have to pay for a headlight kit or bulbs again.
    Features:
    • High power, High brightness, and strong pentrating power.
    • Designed to last 80,000 hours!
    • No warm up time!
    • No relays to run, get a true plug and play high / low setup.
    • Ballasts are solid aluminum with a built in fan.
    • Low voltage protection, high precision constant current driver chip.
    • True Plug-N-Play Conversion Kit.
    • Safe for headlight and fog light, won't melt the housing and runs cooler than stock Halogen bulbs & HID bulbs.
    • Fits into existing headlights or fog lights, no modification or retrofitting required.
    • Bulb lifespan of 5 to 10 years.
    • Ballasts and bulbs are water resistant and shockproof.
    • Waterproof connectors and grommets.
    • Guaranteed for life
    What's Included:
    • 2x Premium LED Headlight Bulbs
    • 2x LED Headlight Kit Ballasts
    • 2x LED Headlight Kit Ballast Fans
    • 1x Installation Instructions
  7. fuzzy1
    10,647
    Oh, I see. When they designed it to last 80,000 hours, they didn't mean operating hours, but only calendar hours.
    If the ballasts need forced air cooling, then I'd also want to know more detail about how well the thermal design requirements of the LED die were handled. Some consumer products are done well, some are quite bad.
  8. sarir97
    sarir97 Member
    265
    74
    Scottsdale, Arizona
    Any updates? Looking forward to a review!
    Turn off signatures in Tapatalk Tapatalk
  9. Priusmpg
    628
    108
    Fremont, California
    2014 Prius Plug-in
    Same here
  10. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    PriusChat member Dawit installed similar high power LEDs in his stock lowbeam projectors.
    He has since switched to an HID kit, Morimoto if memory serves me correctly, because he said the HIDs were brighter and had a better beam pattern over the LEDs.
    Hopefully, he chimes in on this thread and his experience with the LEDs.
    FYI, he's still using the LEDs in his foglights.
    SCH-I535
  11. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Prius Star Ship:
    Did u take the plunge & get these? I'm sure a lot of us would like to see how the output will be in the projectors.
  12. xliderider
    8,140
    3,277
    Honolulu, HI
  13. xliderider
    8,140
    3,277
    Honolulu, HI
