LED replacement for standard halogen headlights?
Discussion in 'Gen 2 Prius Accessories & Modifications' started by uart, Dec 3, 2009.
  1. uart
    uart Senior Member
    4,215
    1,200
    Australia
    A user in another thread posted a link to these LED plug in replacement for halogen headlights.
    Xenon HID White SMD Xenon LED H7 HeadLight Light Bulbs:eBay Motors (item 270495099074 end time Dec-09-09 22:22:27 PST)
    Ignore the misleading name, they're not Xenon HID, they're straight out LED's and designed to run on 12 volts as a standard halogen replacement. I don't know much about them but I'm sure they couldn't work (in the Gen II) because they only have two terminals and I'm pretty sure the Gen II uses halogens with high/low beam in the one bulb (so three terminals). Edit : I just looked it up - the gen II uses "H4" halogen bulbs (aka HB2/9003).
    It sparked my interest though, does anyone know of any aftermarket LED bulbs that genuinely could replace the standard halogen H4's in a the Gen II?
  2. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    I do not think those would be anywhere near bright enough to use for driving around. They're basically for looks. I was looking at them for my fog lights on my Prius V just so the color/look matches the headlights etc knowing that they will not really light anything up well.
  3. uart
    uart Senior Member
    4,215
    1,200
    Australia
    Yeah I suspected they might be a bit of a scam. Wouldn't it be great though if LED's do improve to the point where a plug in replacement like that really is feasible. I want them for their low power and long life more than for their looks.
  4. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    Oh yeah, LED technology is really improving fast. One of the big problems now with a direct replacement is one replacement bulb still wouldn't be enough to replace a halogen bulb. Look at the Prius V, they need 2 separate LED projector beams and an LED floodlight to equal what one halogen bulb does. Also the heat generated by these headlight LEDs is alot. I dont think a housing made for halogens could handle the heat within it if one of those ultra high power leds were rigged into it...
  5. uart
    uart Senior Member
    4,215
    1,200
    Australia
    Well that really is a paradox then Paradox. Because if LED's are more efficient then that implies that they must produce less heat for any given amount of light output.
    If they were really producing more heat than halogen then it would mean that they were less efficient and required more electrical power to operate. In that case I wouldn't want them anyway.
    Actually I think they really are more efficient and they can produce the same amount of light using less power (even with the present technology). I think the real problem is the first one you alluded to. That is, you can enough light in total if you've got enough area of LED's, but you just cant get that much light concentrated in the one small area as per the filament in a halogen bulb. That however is what would be required if we were to have a drop in replacement in an un-modified halogen light fitting.
  6. juzernev
    juzernev New Member
    Hungary
    Conventional bulbs has a incandescent wire which has to be hot to emit light (like fire). They are hot all time.
    While LED are emits light in different way, but there is a current limit, where LEDs begin to produce heat, and less light, efficiency falling dramatically.
    But the technology evolving fast in 2006 demostrated a 131 lm/W at 20 mA diode, and they going for 150 lm/W. (standard bulbs has 15 lm/W efficiency).
    The problem is not with the brightness, but with focusing the light, cause they emmits the light differently (many tiny sources), than halogens.
    Anyway, my 06 prius has combo H4 halogens, so the replacement more difficult (is any).
  7. BAllanJ
    BAllanJ Active Member
    667
    78
    Kingston Ontario
    Those of us in Canada all got halogens due to us running them at low power in the day as DRLs. Can diode lights be turned to a lower output, or is there only one output level, like the HIDs?
  8. uart
    uart Senior Member
    4,215
    1,200
    Australia
    Yes LED's brightness can be controlled very easily (and efficiently).
  9. qbee42
    qbee42 My other car is a boat
    18,058
    3,073
    Northern Michigan
    LEDs are indeed more efficient and produce less heat for the same light output. The problem is how and where the heat is produced. Normal incandescent lights radiate most of the heat away, which is why they feel like heat lamps when you get close to them. LEDs, on the other hand, generate a smaller amount of heat, but it's all concentrated at the semiconductor junction. The junction is very small and not a good radiator of heat, so a large heat sink is required to keep the LED from overheating. Overheating will quickly destroy a semiconductor.
    The need for a heat sink is one of the primary problems involved with retrofitting LEDs into normal light fixtures. It's much easier to accommodate the heat sink requirement with a purpose designed fixture. That's not to say that retrofit LEDs will never work, but it is more difficult to do it correctly, even ignoring the obvious difference in beam pattern.
    Tom
  10. hill
    8,092
    99% of LED's for sale (for example) as R30 can light replacements as well as other applications at your local Home Depot or WalMart state right on the box, "NOT designed for use in 3 way or dimmer applications". So ... how does one reconcile that, along with the idea that LED brightness can be controlled very easily/efficiently?
    Changing the subject slightly, there's a video here on PC showing the HUGE amount of talent/energy/grief/patience needed to take apart a Prius HID headlight for element replacement. Hats off, if you got the time to do all that.
  11. qbee42
    18,058
    3,073
    Northern Michigan
    LED brightness is normally controlled with a pulse width modulator (PWM) dimmer circuit. This is because LEDs don't conduct until they reach some critical voltage. A PMW circuit runs the LEDs at full voltage, but for only a percentage of the time.
    Cheap LED replacement lamps only draw power for a short blip on each AC cycle, close to the maximum voltage at the top of the sine wave.
    The simple dimmers used for normal lights are thyristor controllers that work by controlling the turn on phase angle on the AC waveform. This doesn't work well with cheap replacement LEDs because they are only conducting for a short blip anyway. The dimmer varies how much of the AC waveform the LEDs see, but it doesn't make any difference to the brightness.
    To really work well, the LED drivers need to convert the AC to DC and then do PWM control. Some of the better units do this, and can respond to normal dimmers, but it takes a lot of extra circuitry to make the LEDs backward compatible.
    Tom
  12. kenmce
    kenmce High Voltage Member
    1,512
    496
    NY
    Those are a decorative item and would be awful for actual driving.
    All of the HID family are On/Off by nature. If you underdrive them they won't start. Incandescent (such as Halogen)and LED can be driven harder or softer to make them brighter or dimmer.
    The problem is in the circuitry that drives it, not the LED itself. Most of the LED lights you see in a store are cheap Chinese junk. They don't deserve to be in your house. Those guys won't spend an extra nickel on the design if they can avoid it. This means you get a product that dies if you look at it funny. If you do buy one keep the receipt and packaging (package normally has claimed life expectancy written on it) and write on the bulb the date it goes into service.
    Linkey?
  13. uart
    uart Senior Member
    4,215
    1,200
    Australia
    Yes the ebay ad does seem to skirt around the issue of any exact spec's on how much light they actually put out. They make statements like "hyper white high color temperature" but no real spec's light power levels.
    Interesting though most of the feedback was very positive. I expected to see more comments complaining that they weren't bright enough for actual headlights but all I could find was just one such comment.
    *** "Fast shipping, but not bright at all for high beam, maybe for fog or low beam" ***
    Anyway I still find it interesting the this product is out there. I gives me hope that maybe soon the technology for this will really be there and we'll get true drop in LED replacements for all of the bulbs.
  14. Brian L. Baker
    Brian L. Baker Junior Member
    Now that it is 6.5 years later, does anyone know of reputable LED replacement headlight bulbs for a 2006 Prius?
  15. Augustus88
    Augustus88 Junior Member
    87
    29
    Birmingham, AL
    Three Touring
    SuperBrightLEDs has LED headlight bulbs that are powerful enough to be used as headlights. Their color temperature may be too cool for some people's taste. The light pattern may be questionable in some housings. The only way to know is ask someone who has tried, or try them yourself. I put H4 LEDs in my '94 Miata, the pattern was unusable. In other housings, like the Prius, they may work.
    Semi related, I put LEDs from SuperBrightLEDs in my fog lights on my 2008, they work great. Got the ones with the passive fixed heatsink, not the flexible heatsink or fan heatsink.
  16. Justdidit
    Justdidit LVNPZEV
    1,880
    708
    75
    Carrollton, Texas
    Four Touring
  17. Prius Pete
    Prius Pete Active Member
    183
    178
    Toronto
    I installed LED headlights about a year ago, replacing the halogens. I'm happy with them. They are very bright. At first a lot of drivers flashed at me so I aimed them further down.
    I bought them from AliExpress for about $45 (for 2 bulbs). The exact listing seems to be gone ("40W H4 LED headlight bulb cree led conversion kit") but there are other ones. DRL function works ok for me here in Canada. The bulbs have a small fan and heatsink to keep them cool. Cheaper than many of the replacement halogens available.
