led style bulbs
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Bigleftyinaz, Jul 23, 2011.
  1. macmaster05
    macmaster05 Senor Member
    4,050
    730
    Definitely. Doesn't make sense otherwise.
    In my experience, the $1 eBay bulbs can last just as long as a those from a US store. The difference is color accuracy (some "white" LEDs on eBay have a hint of blue) and lack of warranty. "Higher quality LED bulbs" don't exist on the internet. They're all the same. Which is why I say go for the store that has the best warranty (SBLEDs.com), or go with the cheapest (eBay). Just depends what your priorities are. If you're not skilled enough to make your own like darelldd, it's all a game of luck anyway.
  2. Bigleftyinaz
    Bigleftyinaz Junior Member
    76
    San Antonio, TX
    Great catch.Didn't notice the lack or warranty.
    What about led foglights vs say bulbs from PIAA or hoen? For fogs would led give off more light then the halogens?
  3. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    F8L already gave a good answer in one of your threads.
  4. macmaster05
    4,050
    730
    No. LED bulbs for foglights are pretty useless on the road as far as luminosity is concerned. PIAA or Nokya halogen bulbs are fine, just make sure you get Stage 1 bulbs with the same wattage as stock (<55w). Anything more might melt your harness.
    HID projector foglights IMO are the most effective if they can be aimed at the ground correctly. 3000k color should also help do the trick.
  5. Bigleftyinaz
    76
    San Antonio, TX
    That topic was about HID fogs,not LED
  6. 32kcolors
    5,683
    954
    124
    Redondo Beach, CA
    HID and LED have similar characteristics and both would be useless as fogs if you just stick the bulbs in there. I agree with macmaster that you'd need a 3000K HID projector kit if you want to improve visibility on top of the headlights.
    Unless you don't care about fog functionality and just want an exact match, I'd just stick with the PIAA referenced in stream's thread. PIAAs are a bit whiter and brighter than stock fog bulbs.
  7. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    I agree. Stick with a low Kelvin rated halogen bulb unless you plan on doing projector foglights. Even then most people agree that projectors with halogens are still better for fog. The extra brightness of the HIDs work against you when the light is reflected back into your eyes which causes your retinas to become less dilated. This will ruin your long distance vision. This is also why you don't want the headlights producing a lot of light right in front of the car and why the best headlights are called projectors. They project the light further down the road to increase distance vision.
    Standard LEDs do not produce enough light to be useful for night vision. There are specialty foglights that use LEDs but I don't know if they have any in the size you would need for a Prius and I'm not sure they would work any better than the PIAA bulbs.
  8. Bigleftyinaz
    76
    San Antonio, TX
    I should have been more clearer on how I use the fog lights.
    I use them as driving lights.When I drive at night I turn them on to help give extra light in seeing the road.I drive many miles on rural roads with no road lights and it's tough to see at times and I need to make sure I don't hit any animals.
    I hope that clears this topic up?
  9. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    In that case I suggest HID projectors if you can get them installed. The problem with typical foglights is that they only broadcast light just in front of the car and off to the sides. Having the light to the sides is good for animal viewing but the distance is so short that you will hit them long before you can react. :(
    If you wanted to go all out you could look into having a projector retrofit done. It would likely cost you over $400 but you would have incredible night visibility. lol
    Here is more information for you:
    http://www.danielsternlighting.com/tech/lights/fog_lamps/fog_lamps.html
    Here is a retrofit that makes me drool!
  10. Bigleftyinaz
    76
    San Antonio, TX
    As I was browsing the JDMtoy and SBL sites, I notice some bulbs are with the wording Canbus error free. Are these the ones I should look at?
  11. Bigleftyinaz
    76
    San Antonio, TX
