LED tail light bar
Discussion in 'Gen 5 Prius Technical Discussion' started by je_nuno, Jul 5, 2023.
  1. je_nuno
    je_nuno New Member
    Mexico
    2023 Prius
    Anyone know how to connect the rear Tail light bar?
    #1 je_nuno, Jul 5, 2023
    reallyreal likes this.
  2. purplePriii
    purplePriii Active Member
    275
    123
    What do you mean connect? For the rear brake light like LE vs XLE? Did anyone open the trunk to check if the hardware is even there?
  3. PianoBench
    PianoBench Member
    155
    95
    San Francisco
  4. Hammersmith
    Hammersmith Senior Member
    2,451
    2,516
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Interesting. The first sentence seems to suggest that the kit includes instructions to allow video display on the infotainment screen(even while driving). But I wonder if that's just a mistranslation with the apps I'm using.
  5. purplePriii
    275
    123
    I think in Japan there were people playing videos on the screens from one of the reviews I saw but it seemed odd
  6. KMO
    KMO Senior Member
    2,026
    751
    Finland
    2023 Prius Prime
    Europe manual says it can play videos from USB sticks. And there's a centre-console HDMI port available as an accessory in Japan.
    What they're describing could just be a bypass of the "no video while driving" check - if that's just disconnecting the "speed" input, could have other side effects, like interfering with navigation.
  7. PianoBench
    PianoBench Member
    155
    95
    San Francisco
    This DVD series is just for very very basic tear down of panels that you would want to access if you were to be performing any modifications to interior body panels. It isn't a comprehensive guide to tearing down the engine or the hybrid electrical system.
    It does show you how to access almost all of the cabin's interior parts except the headliner and the panel to the firewall. Everything else you can piece together and be able to modify your car with this DVD.
  8. PhoS
    PhoS Active Member
    258
    210
    Nowhere
    2023 Prius
    Limited AWD-e
    You can also use a carplay dongle like the Ottobox to play Videos, Netflix, Youtube. I've tested it and it works perfectly.
  9. Hammersmith
    2,451
    2,516
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    I don't want to pull this thread too off track, but I just discovered it was pretty easy to trick my car into playing videos(at least YouTube videos). There's a free app for android phones to repackage YouTube for Android Auto. No hacking or jailbreaking needed for either my phone or the car. 75% of the screen gets devoted to the video, while the far 25% stays as nav. I assume there's something similar out there for iPhones and Apple CarPlay. There are risks because you can't get the apps through official channels(Google and Apple don't want liability issues for something like this), but there seems to be a couple safe(ish) options out there.
    (I "watch" a lot of videos that are actually almost completely audio. Maybe a quick glance to the screen every once in awhile. Now I can play them and have my phone in the charger at the same time.)
  10. Chimera1978
    Chimera1978 Junior Member
    45
    San Diego
    2023 Prius Prime
    XSE Premium
    Which app did you have success with?
  11. Hammersmith
    2,451
    2,516
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    I used the AAAD installer and CarStream as the YouTube player. There's also Fermata Auto as an alternative to CarStream. At first glance, I liked the layout of CS better as it's closer to the YouTube desktop look I'm used to. It's not perfect by any means, but it seems to be working ok. Because I'm choosing to basically use a desktop view, the buttons are pretty small for fat fingers. It also locks up from time to time. It doesn't lock up the full infotainment system, just the player. Seems to happen most often if I quickly go to full screen while the app is still buffering the video.
