LED Turn signal bulbs
Discussion in 'Gen 2 Prius Technical Discussion' started by Helio, Dec 17, 2008.
  1. Prius 06
    Prius 06 Member
    283
    29
    Ontario, Canada
    Ok, so I took my dash apart today and found the flasher unit.
    Not sure if I should start a new thread or not, but to be safe will just post the pics I took in here.
    First, I took the first 5 pics that Mike suggested found here:
    http://techno-fandom.org/~hobbit/cars/pwe/
    This is what I ended up with:
    Pic of the Stock Flasher, pin side.
    Pic of the stock flasher, opposite side of pins (visible when plugged in)
    Pannel without the flasher plugged in (on right, next to blue relay)
    Pannel with flasher plugged in (on right, next to blue relay)
    I ordered a led flasher and bulbs today, so hopefully in about 2 weeks I'll have them in the car.
    The flasher number on http://www.superbrightleds.com is: CF18-08. Says "Newer Toyotas"
    Bulbs numbers are: 7440 on there.
    I will post more when they are installed.
    Hope this helps so far.
  2. maseace
    maseace Prius enthusiast
    191
    Poulsbo, WA
    Since I posted that, it appears they are starting to have LED headlights in production cars - the 2010 Prius has an LED option!
  3. maseace
    191
    Poulsbo, WA
    Let us know if this flasher works - I may convert to amber LED signals if it does. I've got enough splices with my other LED mods that I don't have room for load resistors!
  4. Prius 06
    Prius 06 Member
    283
    29
    Ontario, Canada
    There's no reason that it shouldn't work..but I will keep you guys posted after I get them in.
    I wouldn't suggest the load resistors anyways, as they are known for heating up and melting stuff near by. Not to mention the fact that you have to splice into your wiring...which I'd not be a fan of.
    What LED's do you have installed, and where?
  5. thomas124c41
    thomas124c41 New Member
    16
    this setup works, just put in all my turn signal leds tonight along with the flasher unit.
  6. Prius 06
    Prius 06 Member
    283
    29
    Ontario, Canada
    Hey Thomas, thanks for posting.
    Just curious, can you tell me which bulbs you ordered, and where from?
    Thanks
  7. thomas124c41
    16
    I got them from superbrightleds.com, any of the 7440 led bulbs will work, i purchased two of the 3-Watt LED Wedge bulb and two 3-HP LED Wedge bulb and a led flasher
  8. Prius 06
    Prius 06 Member
    283
    29
    Ontario, Canada
    Ok, so you bought the same setup as I bought.
    How do you find them?
  9. thomas124c41
    16
    they are very nice and VERY bright lol, I think I will buy some bulbs for the brake lights and city lights as well.
  10. Prius 06
    Prius 06 Member
    283
    29
    Ontario, Canada
    Brake lights are LEDs, do you mean taillights?
  11. exbauer
    exbauer Active Member
    1,188
    102
    Washington
    could you please take a video of the bulbs in action. i would like to see how bright they are.
  12. thomas124c41
    16
    oh i meant the tail lights at the bottom that are dual filament and constant on. I still need to find a dual intensity led for those, still no luck so not sure if I will replace them.
    I also ordered some new led bulbs for the turn signals. After running around with the old leds I had for a few days without any problems, I started thinking and did a test with the led's during daytime with the sun facing the side that the signals are on. I tested it for the rears signals and realized that its hard to see the orange light in the reflectors if the sun is directly shinning onto them. You can still make out the leds and even though they're bright, they're still relatively small so it may be harder to see. At night of course they're much brighter than bulbs and definately noticeable but I wanted to have something that works in any situation. So I purchased these other types of led bulbs instead, I think these will work better as they will light up the entire reflector. Here is a pic:
    I'll take some pictures once they are installed.
  13. Prius 06
    Prius 06 Member
    283
    29
    Ontario, Canada
    That is bright...I won't get mine in for at least another week, so I'm not sure how they'll look just yet.
    As for the bulbs you'll want for the rear taillights, you'll want the "WLED" bulbs.
    Go here:
    Product Listing - CAR
    Ctrl "F" (find) WLED and it will take you down to the bulbs that are for the Prius' rear lights.
    They aren't dual intensity because the brake lights (factory up top LEDs) are separate from the tail lights.
    The rear tail light number is 2825, which on Super Bright LEDs - Bulb Cross Reference
    (again ctrl "F" the 2825 number) you will see it's WLED.
    Hope this helps.
  14. patsparks
    10,664
    569
    Adelaide South Australia
    Thomas, where are these lights from? I have never seen them like that before.
    I read on a LED web page that it's best to use a red light behind a red filter like a red lens. What have you found?
  15. Prius 06
    Prius 06 Member
    283
    29
    Ontario, Canada
    Patsparks,
    It is reconmended that you use the same color LED bulb as the lense you are putting it behind. Ie: amber turn signal lens would be amber bulb, red lens would be red bulb, etc. Ofcourse, in a Prius, you would use a colored bulb anyways since the lense are clear.
    As for getting a bulb like that, you can get them at www.superbrightleds.com as well
    Look at the bottom, the 2nd last one and up are the same.
  16. Prius 06
    Prius 06 Member
    283
    29
    Ontario, Canada
    Ok guys, I've got my new LED bulbs and flasher in the car.
    They look great.
    The only catch with them is that the lights don't flash when the car is locked and unlocked...I'm thinking it's something with the new flasher as I see no reason the bulbs would cause this.
    No big deal anyways since the car beeps.
    Installing is very easy.
    Here's a video:
  17. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    Hey, thanks for posting all this stuff. I wasn't aware that
    Superbright had a replacement flasher relay that doesn't depend
    on lamp load; I think that's the piece I've been looking to
    exist before trying to do my own conversion because the
    dropping-resistor thing is just so klunky. Which lamps did you
    go with, and why -- i.e. would a straight rear-firing wide angle
    be better or worse than the type with LEDs pasted all over the
    outside so it utilizes the reflector better? The video doesn't
    really show it since the camera tends to get a little blown
    out by the relative light levels...
    _H*
  18. Prius 06
    Prius 06 Member
    283
    29
    Ontario, Canada
    No problem. Just get the newer Toyota flasher (CF18-08)
    and you'll be set. It is a little bit louder then the stocker and the only thing I've noticed is the 4 ways don't flash when you lock/unlock the car.
    I bought the cheapest bulbs ($6.99), 15 led. 9 leds face back and 6 around the side.
    The camera is getting blown out due to the fact that there was no lights on outside. I will take a video of it tomorrow during the day so you can see how they look in daylight.
  19. Prius 06
    Prius 06 Member
    283
    29
    Ontario, Canada
    Ok, here is a video I just took of the lights.
    It's pretty sunny out, and it doesn't look as bright on here as it did on the camera.
    They are pretty bright though. Plus you can always go brighter, these are just the cheap ones.
  20. yunebug
    yunebug Gas Guzzler
    162
    Long Beach, CA
    So, an electronic flasher from superbrightleds.com will work (CF18-08 Flasher Specifications). The question, then, is which LED bulb would be best?
    It came down to these two bulbs:
    7440 xHP3: 7443 LED bulb Specifications
    7440 xLX3: 3 Watt Luxeon 7440/7443 Bulb SPECIFICATIONS
    Comparing the two bulbs side by side, I formed a few questions that you may be able to answer.
    Stats:
    xHP3
    Draws 96mA
    53 Lumens
    620k
    $12.95
    xLX3
    Draws 160mA (use an active driver that keeps the current draw constant over the entire operating voltage range)
    44 Lumens
    590k
    $24.95
    Does this mean that the HP3 is brighter (higher Lumens) AND it's half the price of xLX3? Then, what is the point of buying xLX3 from a consumer's standpoint?
