Led turn signal hyperflash
Discussion in 'Gen 3 Prius Technical Discussion' started by faizaldal6, Dec 31, 2021.
  1. faizaldal6
    faizaldal6 Junior Member
    England
    2012 Prius Alpha
    ----UK----
    I'm experiencing an unusual problem I've had three different sets of turn signal from different venders hazards seem to work fine the right turn signal seems to work fine as well but only the left turn signal hyperflashes they are the mirror turn signals BTW soon as I put the OE one back on its perfect what can be the issue ? I doubt that the relay which is available for Toyota LED flashers will sort such a problem out is there anyone that kindly help it's driving me nuts
  2. AzusaPrius
    AzusaPrius Senior Member
    2,249
    939
    Mirror turn signal?
    So this is aftermarket right?
    Check your connection for that mirror.
    The hyperflash relay is a pain to install.
    I have it installed and it fixes hyperflashing.
    I installed turn signal mirrors after though.
    So both are not related when it comes to hyperflash.
  3. faizaldal6
    England
    2012 Prius Alpha
    ----UK----
    Yes aftermarket led ones
    Only happens on the left side .Hazards seem fine I would guess connection are good because the OE ones work without hesitation doesn't happen on the right side ?
    Relay will it really make a difference ? Issues on one side
  4. Storm88000
    Storm88000 Active Member
    321
    145
    LHValley, PA
    2020 Prius Prime
    What is a mirror turn signal?
  5. AzusaPrius
    2,249
    939
    I believe he is saying he has a pair of aftermarket, driver and passenger mirror LED lights on them.
