Leds under hood
Discussion in 'Prime Main Forum (2017-2022)' started by W8LV, Nov 5, 2018.
  1. Vman455
    Vman455 Senior Member
    540
    556
    The Middle
    Last vehicle I had with an underhood light was a 2005 Ram SRT-10. I don't really miss it; a flashlight works as well or better.
  2. fuzzy1
    10,712
    Has Toyota demonstrated that they can make passenger car engines good enough to have essentially zero risk of running low on oil over 10,000 miles, for the reasonable life of the car? Their recent history is not even close to convincing for many of us. The Gen3 engines most certainly don't qualify.
    The Prime lacks an oil level sensor, so opening the hood to check is the only way to find out in time to prevent damage.
    Trollbait likes this.
  3. Mendel Leisk
    42,354
    A dipstick is the simple and accurate way to see how you're doing when topping up too. Or verifying level directly after an oil change. Scotty mentions that.
    OTOH, I've been bitten so many times, doing oil changes: putting in the proscribed amount, running the engine a minute or two, checking the level, putting in a little more. Then a day or two later, finding it overfilled.
    Now I make a point to NOT check it right away. Put in carefully measured amount, drive it a few days, then check. It's invariably right on the top mark.
  4. Trollbait
    12,831
    Well, the engine bay is where the windshield washer fluid tank is at. Plus a fuse box, and other various fluids.
    Prodigyplace likes this.
  5. Prodigyplace
    12,715
    11,848
    Central Virginia
    People who do not want to open the hood get a BEV. ;)
  6. Trollbait
    12,831
    Even BEVs will need windshield fluid.
  7. smyles
    smyles Active Member
    332
    229
    US
    2020 Prius Prime
    See post #13 on page 1.
    #47 smyles, Aug 31, 2019
  8. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Thanks my dude, great minds think alike.
    Raytheeagle likes this.
  9. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    There can only be one “my dude”:).
    And you’ve designated as such(y).
  10. Prodigyplace
    12,715
    11,848
    Central Virginia
    It could be designed to be filled without opening the hood. Do you open the trunk to put in washer fluid for the rear window?
  11. Trollbait
    12,831
    It could, and cars could be designed to not have the engine in the front. For some, the hood covers a trunk.
    For the companies that didn't expect their customers to ever open the hood, why did they go through the effort of decorating the engine bay with plastic shrouding?
  12. GKL
    GKL Active Member
    543
    265
    South Carolina
    2020 Prius Prime
    Just keep an LED headlamp in the car, they work great as they direct the light right wherever you are looking at, for those not sure what I am referring to just go to the Amazon web site and type in "headlamp" to see a lot of examples. I use one in the house occasionally to read when the light in the room is not bright enough, also when working on various projects.
  13. smyles
    332
    229
    US
    2020 Prius Prime
    Same reason as transparent covers on Ferraris, etc. - bling.
  14. fuzzy1
    10,712
    It could be part of the sales pitch, for the shops that display cars on the showroom floor with hoods open.
  15. Trollbait
    12,831
    "...and if you ever did pop the hood on accident, you won't be offended by the appearance of the car's mechanical workings."
    fuzzy1 likes this.
  16. Prodigyplace
    12,715
    11,848
    Central Virginia
    That boat sailed LONG ago when Lexus & Toyota put the big black grilles on their vehicles. The hood does not need to be open to drive me away.
    I have owned Toyotas as far back as a 1969 Corolla but unless their design changes, my next vehicle will likely NOT be a Toyota.
