Left dash display gone
Discussion in 'Gen 3 Prius Main Forum' started by Cici5, Aug 19, 2018.
  1. Cici5
    Cici5 New Member
    26
    San francisco
    Two Eco
    Hello
    My left dash display where the speedometer is disappeared. We went on a road trip recently in hot hot weather and it would flash on for a few seconds.
    Do you know how to fix? Thank you.
  2. Cici5
    Cici5 New Member
    26
    San francisco
    Two Eco
    Oops 2011 Prius,
    52,804
    welcome!
    test the 12 volt health. if not that, maybe the combo meter. (dash display)
    you can check with art's automotive or luscious garage.
  4. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
    Make sure you don't have anything laying on top of the dash in front of that portion of the display. That display is projected from below the dash, and would be blocked by something laying there. Of course, this does not explain the blinking you mentioned.
    Mendel Leisk and ITBland like this.
  5. Cici5
    Cici5 New Member
    26
    San francisco
    Two Eco
    Thank you.
  6. Cici5
    Cici5 New Member
    26
    San francisco
    Two Eco
    Thank you.
  7. Johnny Cakes
    Johnny Cakes Senior Member
    1,065
    789
    Virginia, USA
    do not know. There are two fuses for the display, #22 and #27. Maybe one blew and then road vibration cause the split ends to touch back together and flash? Really grasping at straws here.
  8. Cici5
    Cici5 New Member
    26
    San francisco
    Two Eco
    Thank you, will try looking at those fuses.
  9. AzWxGuy
    AzWxGuy Weather Guy
    1,078
    558
    Tucson, AZ
    2021 Prius
    Could be a cold solder joint on the display board, or a loose connector to the display board. How about at night, with the lights on. Any display then? With the dashboard lights on, rotate the dimmer through its full range a couple of times. I too begin to grasp toward thin sticks.
  10. BZzap!
    BZzap! Senior Member
    1,607
    878
    I would tend to agree. Cold solder joints at the board connector can cause partial or complete loss of the display. Halo cracks around the pin connectors plague some GM model trucks. Melting points of some of the lead free solders that are used now a days, contribute to the ifailure of these joints.
  11. Cici5
    Cici5 New Member
    26
    San francisco
    Two Eco
    Thank you
  12. Cici5
    Cici5 New Member
    26
    San francisco
    Two Eco
    Ok we tested the battery today. Should be ok.
  13. bisco
    52,804
    i hope so
  14. Cici5
    Cici5 New Member
    26
    San francisco
    Two Eco
    Thanks dash display still the same :(( but hopefully battery ok
  15. BZzap!
    1,607
    878
    At this point, I would consider taking it to a dedicated speedometer repair shop. It seems that the cluster module has a bad electrical component causing your problem. After some research, It is most likely a bad circuit board. In any event, it’s a complex repair if you are not mechanically inclined.
  16. Cici5
    Cici5 New Member
    26
    San francisco
    Two Eco
    Thank you yes and very expensive :(((
  17. Cici5
    Cici5 New Member
    26
    San francisco
    Two Eco
    Just checked they look ok. Thank you.
  18. bisco
    52,804
    there are people who rebuild gen 2 boards for a hundred bucks or so, not sure about 3's.
  19. Cici5
    Cici5 New Member
    26
    San francisco
    Two Eco
    Yes that would help a lot. Have you guys had them help you before???
  20. Cici5
    Cici5 New Member
    26
    San francisco
    Two Eco
    The shop wants more than 2k
