Left fog light stopped working..
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by uhSLEEP?!, Feb 3, 2013.
  1. uhSLEEP?!
    uhSLEEP?! New Member
    Hey, the left fog light on my Prius C4, just stopped working out of no where. I've only had the car for about a month now, and it was brand new when I got it. Is there any tips or guidance anyone can give me to fixing it or checking what's wrong? Thanks.
  2. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Most likely a bad bulb. Both fogs typically have the same fuse so if the right is still working I would chk the bulb
  3. uhSLEEP?!
    The right one is still working, how do I check the bulb? do I just pop off black plastic around the fog light?
  4. Anthony J Nazzaro
    Anthony J Nazzaro New Member
    you can go to auto zone our a ]nother parts store they will help you get it out but what i usually do if one light goes out I change both because i think if one goes the next will go soon just me it's a bulb problem might be made in China Ha! Ha.
    frodoz737 likes this.
  5. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    You would have to loosen the plastic corner piece under the bumper to gain access to the fof light. Not sure if it can be gotten to on the Prii C from under the hood......I know it cant be done on the liftback.
  6. WD0AFQ
    WD0AFQ Active Member
    619
    152
    Dexter, Mo.
    On the left, a kid with a skinny arm can reach down and twist it out. Not so on right. Id probably let the dealer do it under warranty.
    Dan
  7. frodoz737
    frodoz737 Top Wrench
    4,763
    2,539
    33
    And still change them both!
  8. WD0AFQ
    619
    152
    Dexter, Mo.
    Not sure what your question means. The right one will have to be removed after you drop the underpinning on that side or loosen the inner fender so you can get to it. I found that the left one can be taken out from the top if your arm is skinny enough. Mine is too fat to get down past everything. You can shine a flashlight down there and see it from the top.
    I just installed the fog lights a couple of weekends ago.
    Dan
  9. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Did u ever get this figured out?
