Left headlight (low beam) - no power on fuse
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by USBLexus, Apr 21, 2023.
Tags:
  1. USBLexus
    USBLexus New Member
    TX
    Left headlight (low beam) stopped working at all while right one still works. Checked fuse box, fuse 5 - no power, while fuse 4 has power. What could be the reason?
    Not sure if related or not, but left stop doesn't work too, and stopped working at about the same time
  2. Tombukt2
    Tombukt2 Senior Member
    13,864
    2,519
    Durham NC
    How much sitting does the car do. Is this a car that's rarely driven? All of that sort of stuff Texas is a pretty good state for rodents drop your lower glove box clips and pull the tray out for the in cabin air filter You see a lot of mouse droppings squirrel droppings whatever nut pieces??? Maybe take a look at the bottom of your fuse box which is pretty difficult to do and other wiring places You're going to be looking for the electrical diagram and doing some serious tracing It looks like because something has been compromised very interestingly. Like something's been ate or chewed who knows.
    USBLexus likes this.
  3. USBLexus
    USBLexus New Member
    TX
    The car usually is living in garage and been used every day. But was living outside just for 1 week, and it looks like it is enough for someone to chew my wires... it is sad
