Left my 2014 Prius 60 days so far.....
Discussion in 'Gen 3 Prius Main Forum' started by GaryHere, Feb 9, 2015.
  1. Jon Hagen
    Jon Hagen Active Member
    336
    136
    North Dakota
    Ah, good, a man with a healthy happy 12V battery. My 2010 Prius has been hibernating in the garage for going on 3 months now. Have a little BatteryMINDer 12117 charger/ desulfator/ maintainer hardwired directly to the 12V battery posts, keeping it at a healthy 100% charge until the snow and salt goes away.
  2. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    Pearl sat for 5 months several times (Battery Tender on the 12V system). No problem with the traction battery. In fact, the battery indicator didn't change from when she was parked (in the garage). Pearl S also sits for the winter, and that can be from 4 to 6 months, depending on how long it takes me to get tired of pumping glutinous amounts of fuel into the FJ Cruiser. Often the battery indicator shows more charge than when parked. :p
    Again, I use a Battery Tender connected to the boost point to keep the 12V battery happy.
    HaroldW likes this.
  3. kc410
    kc410 Active Member
    263
    255
    2010 Prius IV
    I replaced the traction battery in my Prius with a battery that had been sitting (out of the vehicle) for ~1 year. It measured >212V. It would have dropped right in & worked as-is but I elected to do a few charge/discharge cycles first. It performs like new even today :)
  4. Redpoint5
    Redpoint5 Senior Member
    1,026
    509
    Portland, OR
    Your 2010 Prius had a battery failure?
  5. kc410
    kc410 Active Member
    263
    255
    2010 Prius IV
    Replaced Traction Battery - 2010 Prius | PriusChat
