Left my Prius in the garage (2 Months!..)
Discussion in 'Gen 3 Prius Main Forum' started by iskoos, Sep 2, 2018.
  1. ericbecky
    ericbecky Hybrid Battery Hero
    4,440
    3,308
    Madison, Wisconsin
    It is not a special mode.
    It is simply the way the car operates.
  2. jerrymildred
    jerrymildred Senior Member
    11,517
    14,152
    Tampa, FL
    And the drive train isn't even remotely like a conventional car.
  3. Toyo38289
    Toyo38289 Junior Member
    Oklahoma
    How does the car respond when doing this procedure ?
    Power being applied and the brakes are trying to hold it still ?
  4. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,803
    2017 Prius c
    With my C, exactly nothing happens.
    When the car "knows" that it can't go anywhere......like if it is in PARK or if the brakes are applied.....pushing on the "gas pedal" results in NOTHING.
  5. fuzzy1
    10,463
    If my memory serves (which is not assured), your 2012 was built after the 'Sudden Unintended Acceleration' or 'Runaway Toyota' fiasco, so may have an upgraded brake-throttle lockout help prevent those purported incidents. Those events were mostly driver error, with some cases of mechanical interference thrown in, but there is no certainty that none of them were drive-by-wire control faults.
    OP's 2010 was built before that change, so has only a partial throttle defeat.
  6. Threej
    Threej Member
    99
    99
    Portland, OR
    I don't know what you guys are talking about-- I tried this once on my 2010, and all that happened was the car tried to fight against the breaks and go...
  7. ericbecky
    4,440
    3,308
    Madison, Wisconsin
    My mistake. I had it in my head that this was a gen 2.
  8. iskoos
    iskoos Active Member
    415
    254
    Orlando, FL
    Topping of the hybrid battery will not be necessary as seen in my example. My 8-year-old batteries held up pretty well (5 bars to 4 bars after 2 months). Leaving it around/above half charge should be plenty.
    I also never heard of power-braking.
  9. Grit
    Grit Senior Member
    6,573
    4,227
    Wilkes Land
    It does work on turd gen, the guy with grocery stickers on driver door does this as he's at the starting line of racing.
  10. Maarten28
    Maarten28 Active Member
    415
    224
    Netherlands
    It stays stationary.
    What happens mechnically? There are 3 inputs to the "gearbox" and one output. Inputs are the Internal Combustion Engine, MG1 and MG2, the output obviously are the wheels. MG2 has a fixed relation with the output to the wheels, so when stationary, MG2 will not spin. That means when the ICE is running, MG1 has to start spinning. It will do this with a relation of about 3.6:1 to the rpm of the ICE and should max out at 10,000 rpm (which is 2,778 rpm for the ICE).
  11. ericbecky
    4,440
    3,308
    Madison, Wisconsin
    It's definitely a thing.
    Great for burnouts with muscle cars.
  12. Toyo38289
    Oklahoma
    You actually do this to customer's cars ?
  13. Prodigyplace
    12,569
    11,781
    Central Virginia
    Muscle car Prius?
    You mean this one?
    Hellcat-Powered Prius
  14. Yaesu
    Yaesu Member
    111
    34
    Kentucky
    We have two Prisus'. One is stored in Florida through the summer for six months (no AC) and the other is stored in Kentucky for six months during the winter. Both vehicles were stored with relatively full HV batteries. A maintainer is connected to the 12-volt batteries. We've been storing one of them every six months since 2010, and the other for the past two summers. The only problems we've had were the 12-volt battery failing (while on the maintainer) and engine knock when the Kentucky Prius engine starts in the spring.
