Left Rear Door Panel
Discussion in 'Gen 3 Prius Technical Discussion' started by El Dobro, Jan 5, 2013.
  1. El Dobro
    El Dobro A Member
    7,102
    3,282
    Is it a big deal to remove the left rear interior door panel? The dealer replaced the door glass and, naturally, the tech didn't align the glass correctly. :rolleyes: I'll align the glass myself.
  2. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    I have removed the driver's door panel but not the rear. The driver door panel came off like most others that I have removed. Toyota uses the same automotive plastic, tapered push-pins as most others. I have a slotted tool for interiors that slides between the panel and the door frame that helps with the push-pin removal.
  3. El Dobro
    El Dobro A Member
    7,102
    3,282
    Ok, I just want to make sure there's no hidden screws. I know there's one in the door pull pocket. Is there one behind the cover behind the door release handle?
