Left rear wheel looks strange
Discussion in 'Gen 2 Prius Technical Discussion' started by jjltthomas, Oct 12, 2017.
  1. jjltthomas
    jjltthomas Junior Member
    Section, Alabama
    The left rear wheel on my wife’s 09 Prius appears to be in at the top but tire wear is normal. However I have noticed excessive gap difference between driver side tire gap and passenger side gap. Feels very stiff to the left side as well is this normal? Has anyone else experienced this?
    iPad ?
  2. jzchen
    jzchen Newbie!
    3,296
    1,006
    Arcadia, CA
    Possible spring failure?
  3. scona
    scona Active Member
    225
    206
    Courtenay, BC, Canada
    2013 Prius v wagon
    If you have a flat spot at home to park on jack up the left rear wheel about 6". See if the wheel remains in the same position or moves inward or outward. Try grasping the wheel at top and bottom and see if it is tight or will it wiggle? Are the wheel nuts securely tightened? If there is any movement get it towed somewhere for proper examination. Do not drive it anywhere. If none of the above happens it probably is safe to drive somewhere to get a professional opinion, Toyota dealer or front end, alignment shop.
  4. jjltthomas
    Section, Alabama
    Sounds good I will try that tomorrow.
    iPhone ?
