Left the headlights on...car won't turn
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Erin Riel, Dec 29, 2017.
  1. bisco
    52,830
    yes, take it in. they might try to charge it and give it back to you if it passes. if not, they should give you a new one.
    i would not tow it in unless i had to. call them and ask.
    Erin Riel likes this.
  2. Erin Riel
    Erin Riel New Member
    28
    Massachusetts
    Interesting! Great learning experience -- thank you, again!
    bisco and Raytheeagle like this.
  3. William Redoubt
    William Redoubt Senior Member
    1,228
    1,174
    Coronado Island, California
    The Prius doesn't take much battery power to start the car. But you have to be careful.
  4. Sam Spade
    Sam Spade Senior Member
    2,036
    1,024
    2017 Prius c
    A dead battery is more likely to freeze. How likely depends on how dead it is.
    Other than that, cold will actually prevent some of the damage from sitting in a discharged state.
    The best "fix" for this problem is to leave a small charger connected at the jump points for 12-24 hours to be sure the battery is fully charged again. Just normal driving might not bring it back to "full" for days or weeks.
  5. bisco
    52,830
    that's what i did with my daughter's '08 the other night when it was dead. in the morning (6 degrees) it started fine, and she was able to drive it to the mechanic for replacement.
  6. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    Erin, hopefully everything turned out OK this morning so turn this into a learning experience and get a small jump pack to leave in the car. Powered by a small but powerful LiOn battery that periodically needs a refresh charge (topping off), it will have enough juice to immediately "boot up" the Prius and allow the big hybrid battery to crank start the gasoline engine. Even in a worst case scenario and allowed to lose most of its charge (it would take months), you could quickly refresh the jump pack in a few minutes from any wall plug before starting the car.
    For use in the Prius, you don't need one promising to crank-start an F250 diesel as that is overkill; it only needs to provide 12 volts to get the computers back online and open the HV battery contacts. Once started, you'll want to leave the car on for a long period (30 min.) to allow it enough time to charge the 12v back to normal levels. If safe and secure, you can simply just leave the car on and in Park to do this. Non-hybrids typically need to be driven to get the charging system up to the 14v region but anytime the Prius is on (ready mode) it is putting out 14ish volts to the little 12v battery. Note: don't use accessory mode; must be in ready mode!
    automotive jump pack - Google Search
    Erin Riel and Raytheeagle like this.
  7. Erin Riel
    28
    Massachusetts
    Happy to report a normal jump resolved the situation! Thank you all for the help!
    bisco and scona like this.
  8. Mendel Leisk
    42,331
    Well yes and no. I would recommend to get a smart charger, 4 amp range hook it up and let it run to completion.
  9. Erin Riel
    28
    Massachusetts
    My thinking as well! Of course rn the roads are terrible, not ideal for the situation. I was hoping to give it a good drive at least to start.
    What smart charger would you recommend?
  10. Erin Riel
    28
    Massachusetts
    No kidding? That's really interesting!
    Right now I had to move the car in the driveway to let another car get out (three hours after jump) and thankfully it started fine. I've left it in ready mode to charge and am watching from the comfort of my family room beside the pellet stove fortunately it's a very secluded residential area with no remote chance of theft.
    #30 Erin Riel, Dec 30, 2017
  11. Mendel Leisk
    42,331
    I've used a couple of CTEK's: the 3300 and the 4.3. Prices have gone up on them, it's a bit surprising. I use the 4.3 primarily now, but the 3300 is cheaper/simpler, and perfectly fine.
    kc410, scona and Erin Riel like this.
  12. Erin Riel
    28
    Massachusetts
    Not horrible prices -- definitely a good thing to have and knowing me it'll be worth the buy
    scona and Mendel Leisk like this.
  13. Sam Spade
    2,036
    1,024
    2017 Prius c
    One good choice. But not to be confused with the cheap junk that Harbor Freight sells under the CEN-TEK brand name.
    Also Battery Tender brand. Schumacher from WalMart.
    Any brand name that you recognize from an auto parts store; Die Hard comes to mind.
    A good automatic charger with 2 to 4 amp capacity should be priced from $20 to $30 or so.
  14. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    I bought two of these (one for in the garage, and one in the house to trickle-charge the various 12V packs I have laying around)
    from Sears: (DieHard 6V/12V Battery Charger & Maintainer 28.71219) - I bought them back in the fall in a sale for ~$20 each. I have one of the pig-tails permanently wired into the fuse-box of my 2009 Gen II Prius so that it can be plugged in every time the car is in the garage! Here's a picture of the pig-tail:
    Ooops :oops:, I meant to post this one (…shows location where it's wired in!)
    #34 WilDavis, Dec 30, 2017
  15. kc410
    kc410 Active Member
    263
    255
    2010 Prius IV
    Thank you for the suggestions Mendel. I just ordered a 4.3 - been meaning to get a decent smaller fully automatic charger - guess I could call it a late Christmas present to myself :) - (although the 2015 four in the driveway is a somewhat bigger Christmas present, more on that in a later post)
    Mendel Leisk and Raytheeagle like this.
  16. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    Does the later post come complete with pics:whistle:?
  17. kc410
    kc410 Active Member
    263
    255
    2010 Prius IV
    I'll start a new thread with the whole story ;)
    Raytheeagle likes this.
