Left Turn Signal Intermittent
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by taxibuddy, Mar 23, 2018.
  1. taxibuddy
    taxibuddy Member
    79
    57
    Atlanta
    2014 Prius v wagon
    My left turn signal started working intermittently today. When it works, the left front turn signal, the left rear turn signal, and the dash indicator light all work correctly. When it doesn't work, the left front turn signal, the rear left turn signal, and the dash indicator don't work at all.
    When the problem is happening, I have tried turning on the hazard lights. Only the right side lights flash and only the dash right indicator flashes.
    Any ideas of what could cause this?
  2. Elektroingenieur
    2,515
    3,259
    Three Touring
    A defective combination meter or, perhaps, an intermittent short to ground on the left turn signal circuit would cause the symptoms you describe.
    See the Turn Signal and Hazard Warning Light diagram in the System Circuit section of the Electrical Wiring Diagram, available by subscription to techinfo.toyota.com.
  3. Air_Boss
    Air_Boss Senior Member
    3,952
    1,083
    New Yawk
    Intermittent contact on the turn signal stalk, or does the 4-way/hazard behavior rule that out?
  4. taxibuddy
    taxibuddy Member
    79
    57
    Atlanta
    2014 Prius v wagon
    It doesn't seem likely that the problem is on the input side since there isn't any common wiring between the turn signal switch and the hazard switch that wouldn't also prevent the right side from working.
    What I'd like to do is disconnect the left side output to both indicators to see if the dash light starts working again. Either that or connect the left side indicators to the left side output but unfortunately it's very difficult to get to the wiring. Everything is working ok today so I guess I'll wait until it pops up again.
  5. frodoz737
    frodoz737 Top Wrench
    4,297
    2,348
    33
    I only have the 2010 Liftback prints handy, but my guess is the systems are very similar. Good luck.
  6. taxibuddy
    taxibuddy Member
    79
    57
    Atlanta
    2014 Prius v wagon
    Thanks, the v is a little different. I have the corresponding v diagram. It's physical access to the components that's the difficult part.
  7. MarkShellhamer
    MarkShellhamer New Member
    PA
    Three Touring
    I'm having the same issue but on the right side. Was there a resolution to this issue?
