Lessened performance in 2017 Prius 2
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Jtimc7, Feb 28, 2018.
Tags:
  1. Jtimc7
    Jtimc7 Junior Member
    Dallas, Texas
    I bought a Prius 2 in December and have put just over 1200 miles on it. Over the last couple weeks it has seemed that its performance has lessened a bit. Might I have changed a setting or something that might have caused this?
  2. DavidA
    2,349
    1,825
    Chicago western burbs
    You might notify the moderator to move your post to the appropriate forum for relevant responses. You can use the [ Report ] button for that.
  3. Jtimc7
    Dallas, Texas
    Thank you DavidA!
  4. Prodigyplace
    12,711
    11,848
    Central Virginia
    Welcome!
    I have had my 2017 Prius Two since October 2016 and now have 13K miles.
    I have not been monitoring Texas weather. Have you been having colder weather in the last couple of weeks? In colder weather the engine needs to run more to keep at an efficient temperature. Running the cabin heater makes the engine run more too, to keep warm. The Prius is more susceptible to mileage changes due to temperature than many other cars.
    We have what is known here as a Generation 4 Prius
    The main forum is here.
    Gen 4 (2016 to Current) Toyota Prius Forums | PriusChat
    RCO likes this.
  5. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    Have you changed modes - they don't really affect power much, but the apparent "feel" is different - PWR has the throttle more of a fast response trigger, ECO, much more reserved. I prefer ECO, as it's easier to moderate. But in stop-start traffic where I'm letting DRCC do most of the throttle work, I'll use PWR mode as it responds better.
    Maybe you've been trying harder to eke out the last kilometre per litre - means you'll go a bit slower. Has your fuel economy changed?
  6. Prodigyplace
    12,711
    11,848
    Central Virginia
    I disagree. Changing modes affects DRCC responsiveness a lot. I run in Normal mode because I think the accelerator is too sensitive in PWR mode.
    pilotgrrl and krmcg like this.
  7. bbald123
    bbald123 Thermodynamics Law Enforcement
    386
    275
    Harrisburg, PA
    I agree with the observation.
    The key here is throttle response curves. It is least responsive (at other than wide open throttle) for ECO mode and most responsive in PWR mode. It doesn't matter whether the throttle is controlled by your foot or the DRCC.
  8. Prodigyplace
    12,711
    11,848
    Central Virginia
    I would like to see them decoupled though, at least as an option. I might drive in Eco mode more if the radar cruise control were as responsive as it is with the radar off.
  9. krmcg
    2,592
    2,393
    Whittier, CA
    I find that whatever mode I am in, my calibrated foot drives as if in ECO. I like that the choices of throttle responses independent of my input.
  10. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    The only time I use any other mode than normal is when in snow, I use eco to lessen the throttle response and prevent skidding. I find power mode too jerky, maybe because I'm so used to normal mode.
    To answer the OP, if you haven't changed modes, make sure the manual, foot operated parking brake is fully off. Also check if any of the wheels are hot after a journey, indicating a sticking brake.
    RCO likes this.
  11. bisco
    52,804
    once in awhile, you get a defective car. take it in to the dealer while it is still under warranty, and have them run a health scan.
    RCO, padroo and Tande like this.
  12. pilotgrrl
    pilotgrrl Senior Member
    891
    1,797
    Chicagoan in TX
    Are you taking many very short trips, or a few long drives? Do you use the heater a lot? Do you drive for MPG or not?
    The weather here hasn't been too bad, but I'm from Chicago. I use ECO mode and try to avoid using the heater as much as possible.
    I also like to drive the speed limit, and it takes me 20 minutes to get to my workplace, although Google Maps usually says it should take 11-13 minutes. (I think Google Maps doesn't realize that traffic has gotten worse now Toyota has finally moved to Legacy West.)
  13. Fester
    Fester Active Member
    201
    198
    Ohio
    Eco Mode works well for me, just wondering about your comment on the DRCC with Radar off.
  14. Prodigyplace
    12,711
    11,848
    Central Virginia
    If you hold the cruise control on button (for 3 seconds?), it switches to non-radar cruise control. You can customize that to be the default mode IIRC.
    It is interesting to try, especially on a road with varied terrain.
    pilotgrrl likes this.
  15. alanclarkeau
    7,045
    7,593
    I think he meant NORMAL Cruise Control, not RADAR.
    I tried it once - after 3 minutes, I thought, how old-fashioned and went back to RADAR.
    RCO and kithmo like this.
  16. bisco
    52,804
    maybe bad gas.
    kithmo likes this.
  17. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Or high ethanol content.
  18. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Now your just being over-polite. ;)
  19. alanclarkeau
    7,045
    7,593
    I'm still trying to understand the "bad gas" ...
  20. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    RCO and pilotgrrl like this.
