Lets Fix That Prius
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by johnnychimpo, Feb 21, 2021.
  1. rjparker
    rjparker Tu Humilde Sirviente
    11,116
    6,974
    Texas Hill Country
    What is the 12v battery currently reading? Did you allow a few minutes during the jump attempts to equalize the 12v batteries?
    Most p-lock problems are caused by a low voltage battery. A quick jump will not always raise the voltage enough especially if the 12v battery is damaged.
    It is hard to understand what you are writing.
    CFB2E018-E216-431B-ACF2-D9293612CCAB.jpeg C9822AE4-173C-42E5-87DB-7B51775A4972.jpeg 46EC059D-28D0-4C23-B5F2-2768E520387A.jpeg
    #21 rjparker, Feb 27, 2021
  2. johnnychimpo
    johnnychimpo Active Member
    522
    112
    Monterey
    Sorry I was on my phone outside for most of this. Now aux battery is at 11.4 so battery is low needs to be replaced. so I have connected my truck battery to the car I know the truck battery is good but the result is the same with the p-lock. Truck battery reads 12.5 volts
  3. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
    Start checking the fuses, and maybe try clearing the codes before scanning it once again. Are the above DTCs current?
    Do all of the lights work; dash, dome, etc.
  4. johnnychimpo
    522
    112
    Monterey
    yes dome lights work and all dash lights. I cant use my generic odb Im using this tech stream seems to have more functionality.
    I will check fuses in the morning. do relays go bad suddenly like fuses or what is the behavior
  5. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
    Generic OBD2 scanners rarely work well, or will return false codes (DTCs), it would be best to only use techstream.
    What are the current DTCs (obd2 codes) again?
  6. johnnychimpo
    522
    112
    Monterey
    where would you focus? im thinking power source control. or ECM(Engine) either a fuse is blown or relay. would you happen to know which I should check? I see the prius ECM goes for 30 to 100 bucks on ebay. Even if this is the issue do I need to reprogram it? if so is it hard to do?
  7. johnnychimpo
    522
    112
    Monterey
    I FIXED THE ENGINE NO START! is was IGN #2 fuse in the engine bay.
    now on to replacing the engine bay diagrams on the cooling reroute to get the 2016 engine into the 2010?
    Mendel Leisk and SFO like this.
  8. johnnychimpo
    522
    112
    Monterey
    ON a side note this bothers me the only reason for a height difference in piston travel height is a bent rod worn bearing right as the car runs fine. Just the misfires here and there.
  9. Mendel Leisk
    42,354
    Compression roughly the same on all?
  10. johnnychimpo
    522
    112
    Monterey
    first three yes number had higher comperssion. like 190
  11. Mendel Leisk
    42,354
    And #4 lower?
    How about a new short block? They’re about 2 grand though.
  12. rjparker
    11,116
    6,974
    Texas Hill Country
    Now the compression was 190?
    Haven't you already sourced a 2016 gen4 engine with 10k miles?
    Are you planning on using the old gen3 egr and intake as others have done?
    Do you have a mechanic that is doing this swap for you?
  13. johnnychimpo
    522
    112
    Monterey
  14. johnnychimpo
    522
    112
    Monterey
    What tool do I need to remove flywheel and fuel line ?
