Let's have an honest top 20 fuel efficiency, seperate EV and HV
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Jerry Liebler, Oct 31, 2014.
  1. Jerry Liebler
    Jerry Liebler Member
    177
    85
    Science Hill Kentucky
    2013 Prius Plug-in
    I agree, but can't see how to really use it. Since we typically use a trip odometer to track the tank anyway, it's just one more note to take.
    51,799
    i'm sure a mathematician could arrive at some formula to quantify efficiency based on speed.
  3. Jerry Liebler
    177
    85
    2013 Prius Plug-in
    I apologize for the inept choice of words in the title, it would have been better to just say MPG and MPGE as these are the American units of what is colloquially referred to as fuel efficiency.
    NO the ratio is correct! The EPA states one gallon is equivalent to 33700 watts. Therefore gallon=33700watts. MPG=miles/gallons, MPGE= miles/33700wats.
    As to what I wanted when I made the initial post, it is now in the spreadsheet.
  4. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    Yet oh so difficult to interpret in the context of mileage champs. Consider what stops at red lights do to MPG (or MPGe).
    The proposal of OP to crown EV and HV champs is not going to work.
    Consider two PiPs competing by going up and down a hill:
    Car 'A' goes up the hill in HV, and down the hill in EV. Bravo! He is the EV champ
    Car 'B' goes up the hill in EV, and down the hill in HV. Bravo! He is the HV champ
    If the above does not convince you that this competition is flawed, just remember that no one is controlling for EV charges per mile. The person who charges up every 10 miles is sitting pretty no matter how they drive.
    Really folks, what is this competition about ?
    Least liquid fuel per mile ?
    Least source energy per mile ?
    Least transmission to wheels energy per mile ?
    Something else ??
    An MPG(e) competition is pretty much an EV/HV ratio competition.
    OP: yes, MPG(e) is ~ miles/33.4 kWh. Just try not to compare 33.4 kWh of energy in a battery to 33.4 kWh of energy in a liquid fuel tank.
  5. bisco
    51,799
    you know you want one.:sneaky:
  6. Jerry Liebler
    177
    85
    2013 Prius Plug-in
    SageBrush asked: "Really folks, what is this competition about ?"
    My answer: It's personal! I view the PIP as a tool. I have personal pride and strive to use all tools in the "best" way(s) possible. Knowing how I rank among peers using similar tools motivates my search for ways to better use tools such as the PIP.
    The newly added column on the spreadsheet is a score of performance against the EPA benchmarks and will resolve weather it's better to use EV or HV up hills as I'll try both.
    As to the "speed" data, this too could potentially be factored into the "score" put it is much more complex and, unlike HV vs EV we don't have benchmark data. But we, potentially, could find a single data point in the average speed of the EPA test cycles.
    The problem of waits at stop lights affecting speed and fuel economy can be addressed by the driver who can simply turn power off during such waits. Such action will raise, indicated, average speed with minimal effect on fuel use rates.
  7. markabele
    5,084
    1,782
    Nebraska
    IMO...if you really want to see how good of hypermiler you are...don't plug in for 500 miles and see how well you can do. Then go post in the Top 20 MPG thread over in the regular Prius area. Those are some scores that will be tough to beat.
    My guess is you will just say something similar over there. Here you say it's just a ratio challenge. Over there you would simply say it's just an average speed challenge. Hard to make a truly fair Top 20 whatever way you slice it since we aren't all driving on the same track with the same variables. Correct?
    fortytwok likes this.
  8. SageBrush
    11,627
    2,533
    Southwest Colorado
    I agree on both counts.
    By the way, I had my Prius (v)agon at ~ 86 MPG over 300 miles a few weeks ago, but then my wife went on a high speed, 400 mile trip and that was the end of that LOL
  9. markabele
    5,084
    1,782
    Nebraska
    Dang, that's pretty amazing!
  10. SageBrush
    11,627
    2,533
    Southwest Colorado
    You would have been even more impressed if you had seen the rural road conditions. Not pebble stone grade, but much rougher than a good road. I know from patches of good roads that I can reliably hit over 100 MPG on return trips if I P&G.
    Then again, everyone can hit over 100 MPG in any Prius if driving is limited to P&G in good weather, good roads, and very few stops.
  11. Jerry Liebler
    177
    85
    2013 Prius Plug-in
    By using the "score" concept of % improvement over EPA data I can quickly see that currently the best hypermilers among Prius drivers are not driving PIPs. Intuitively I feel the PIP actually should have an advantage but hypermiler EV skills haven't been developed to the same extent as HV.
    Why the PIP should have an advantage, especially at higher speeds.
    ICE off glide speed is limited to 42 in all but the PIP, in the PIP, by selecting EV ICE can be shut down @ below 62
    #31 Jerry Liebler, Nov 3, 2014
  12. bisco
    51,799
    it's actually more difficult to p&g in the pip because the battery tends to hold a higher charge and the software tries to expend it when your trying to glide. it can be a real battle. also you tend to lose your skills because when you do have a charge, you can glide forever, maintaining speed with a tiny bit of battery use.
  13. SageBrush
    11,627
    2,533
    Southwest Colorado
    In the Gen3 Prius family Glide is possible up to 45 MPH.
    Second, while a PiP can glide at a higher speed that does not mean less energy is used. PiP or Prius, traveling at 60 MPG takes more energy than traveling at 45 MPH. It is primarily a matter of air friction.
  14. fortytwok
    fortytwok Active Member
    467
    139
    Hopkinton MA
    2013 Prius Plug-in
    and you think that couldn't be gamed either ?
    speed / route...
  15. slcMPG
    slcMPG Member
    221
    65
    SLC, Utah
    Sure it could, but I was more thinking of a for fun thread without a top listing in the first post. Some may take it serious but, others could just post up a single shot and not worry about it. I am always amazed at how easily this car can blow past the EPA ratings.
