Lets see your Charge station Photo
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Bill Collins, Oct 9, 2013.
  1. Bill Collins
    Bill Collins Junior Member
    East rutherford N.J.
    2013 Prius Plug-in
    IMG_0486.jpg Mine is in my driveway.. its a leviton model EVB45-3PT 240 VOLT as you see in the pic
    Hi Burrito! likes this.
  2. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    In my garage
  3. Bill Collins
    2013 Prius Plug-in
    If you click on my small pic it will enlarge..I have it Hardwired but we put a new hole in the side and blocked the bottom where the short cable with the plug was ..Added a safty shut off (Top Box)and second set of outlets (In a bubble Box)..one a 110 and another 220 for the upgraded Prius evse..all on a post and 24"x24" plywood . was going to use the nema box in the rear but now its just a storage box for whatever
  4. -1-
    -1- Don
    1,254
    439
    Chester, Virginia
    2024 Prius Prime
    :)Nice work guys. This was my second install, to what I figured was the ideal location. Required running another 240v dedicated line. I only have to deal with the six foot section of cord which hangs on a hook.
    Hi Burrito! and bvoyles like this.
  5. uropip
    uropip Member
    138
    38
    S.E. MASS
    2013 Prius Plug-in
    not fancy by any means...
    Leviton Level 1 jobby with selectable amperage
  6. davidhuff
    davidhuff Junior Member
    63
    Salem,OR
    2013 Prius Plug-in
  7. davidhuff
    63
    Salem,OR
    2013 Prius Plug-in
    Who makes this charger?
    Sure looks great!
  8. -1-
    -1- Don
    1,254
    439
    Chester, Virginia
    2024 Prius Prime
    :)Leviton, same as Bill Collins in the first post. My is the 16A version, his is the 30A.
  9. markrivers
    markrivers Junior Member
    88
    Beverly Hills
    2020 Prius Prime
    It's a Leviton with 40amps
  10. bina12834
    bina12834 New Member
    28
    man i wish i had a driveway or garage so i could install a charging station.
  11. markrivers
    88
    Beverly Hills
    2020 Prius Prime
    ^ actually, i live on a 3rd floor. this installation is on a hallway ( 1st floor) near a common garage. The electrician constructed a conduit from my main panel all the way to where it's positioned now.
    It was hard and expensive. But it was worth it.
    -1- likes this.
  12. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    All of you fancy folk. :p
    I went el cheapo. $220 for a 220v EVSE upgrade PIP EVSE. $150 for a 220v outlet and circuit breaker install. A couple cents for a screw and zip tie.
    chesleyn and Hi Burrito! like this.
  13. SimiPrius
    SimiPrius Member
    247
    60
    Simi Valley,Ca
  14. chesleyn
    chesleyn Active Member
    596
    158
    Los Angeles
    Here here.. I went el cheapo too (y)
    Mine is outside though.
    F8L likes this.
  15. retired4999
    2,652
    627
    Eau Claire, Wi.
    My moto always. The KISS method! :)
    Screw eyelet on wall, screw through hole on cord box.
  16. hill
    8,988
    For those that go the cheep route - just make sure what you're doing is to code / safe. Do NOT be the 1st PiP owning person (like the Volt owner below who went cheep on their charge wiring) to get laughed at for cutting corners.
    F8L and jdk2 like this.
  17. jdk2
    jdk2 Active Member
    751
    220
    Raleigh, NC
    2013 Prius Plug-in
    Man, that's no lauging matter. If the fire didn't kill me, SHE would!
    F8L likes this.
  18. mrbigh
    3,686
    699
    Long Island, NY
    Now the Family is " Char...plus"
  19. pwp1943
    pwp1943 PHEV Afficionado
    51
    Boston
    2013 Prius Plug-in
    Here is my EVSE level 2 charger. It came from the OpenEVSE project as a kit. The kit can be found on the web with a Google search. The kit box is mounted on the inside wall of my garage. I had to have a 220 volt outlet wired from my breaker box. The orange wire goes to a 220 plug. The plug for my box is only about 20 feet away from the outlet so wiring was easy. It is wired for 20 amps in case I need higher current for a future car. The PIP only needs 9.5 amps at 240 VAC, so I fused the EVSE box at 15 amps and put 15 amp breakers in the main box. In addition there is a circuit that senses maximum charging current in the electronics and it is set to disable the charger at 10 amps. There is plenty of safety and margin in my installation. As a benefit it only takes about 90 minutes to get a full charge compared to the Toyota supplied cable.
      File size:
      70.9 KB
      493
    mrbigh likes this.
  20. SAronian
    SAronian Active Member
    334
    144
    Oakland, CA
    Me too. Seemed like a flexible and winning combination.
    F8L likes this.
