Let's talk about the Prius AWD
Discussion in 'Prime Main Forum (2017-2022)' started by elendilmir, Mar 18, 2019.
Tags:
  1. Trollbait
    12,817
    Found some listings with a straight google search, but I didn't bother checking on existence at first because I knew there wouldn't be many if there were. It was the last to get a hybrid option, and then Mazda started cutting ties when Ford sold off their controlling interest.
  2. ChapmanF
    18,993
    That must explain the sluggishness everybody complains about in the Teslas ... no gas engine connection to the wheels.
  3. Mendel Leisk
    42,303
    I was thinking ground clearance was slightly less with the AWD option? Anyway Toyota Canada spec's them all the same:
    Nothing's stopping you putting snow tires on the AWD model. That should be a good combo.
    drash likes this.
  4. Tideland Prius
    16,675
    That’s wrong. I saw 5.1 and 5.3. 4.8” is the value for the Prime.
  5. Trollbait
    12,817
    :) eAWD systems on hybrids do have operation limits based on the motors and battery power. The Prius' system uses a low power rear motor, which limits AWD use to starts and low speed. Use a larger motor, and the system becomes limited by what electricity M/G 1 can send after meeting the needs of the front traction motor. the battery can supplement that, if it has available charge.
    A mechanical AWD system doesn't have those limits. If the engine is supplying power, power can go to all the wheels.
    PHEVs and BEVs avoid the limits hybrids have on eAWD systems by having much bigger batteries.
  6. Mendel Leisk
    42,303
    Was it the AWD version with the 5.1"? That's the recollection I had; it struck me odd. Still, not even a 1/4" difference is pretty fiddly, lol.
  7. Tideland Prius
    16,675
    The AWD version has the higher ground clearance. It’s basically the “rough road” spec that we saw on in the new car manual from TechInfo.
  8. Trollbait
    12,817
    Japan may not have road salt, but they have great snow removal.
  9. jb in NE
    jb in NE Senior Member
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    This is $1,000 plus for the AWD, then another $600 plus for snows (depending on whether you have the snows on separate wheels). For my money, I'd just put the snows on, since the AWD is very limited in performance and power, and is unlikely to improve on the performance with FWD and snows.
  10. Mendel Leisk
    42,303
    If I had the AWD Prius I could NOT resist putting on snows, lol.
    fuzzy1 likes this.
