Let's talk about what we'd like to see in the next Prime update.
Discussion in 'Prime Main Forum (2017-2022)' started by Prashanta, Aug 20, 2018.
  1. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    I'm NOT an engineer.
    But I know a lot of you are.
    So my question is...
    Would the adoption and application of the "Dynamic Force Engine" be a challenge, simple, hampered, or impossible for a vehicle that is simultaneously employing a Atkinson Cycle engine?
  2. Trollbait
    12,539
    This engine is already in the Camry hybrid.
    If it or a sibling isn't in the next Prime, it is because Toyota decided sticking with older technology was a good trade off for keeping costs and price down. If the hybrid Prius is still around, it will use it.
  3. hill
    8,805
    actually - some of us (including Bob) PC folk HAVE spoken w/ Prius engineer folk - & we were speaking English.
    there is at least one hybrid already that has no 12v aux battery so ... yes, that expectation is already available.
    1- 5th seat
    2- liquid cooled traction pack
    3- seats, mirrors, lumbar support, telescoping & height adjusted steering memory based on which fob is in driver's seat.
    4- no ICE
    5- bigger hatch w/out wiggly glass, + a wiper
    6- 300+ mile range
    7- DC QQ
    8- 2½ Ton tow capable
    9- ditch the corny giant look of air holes up front
    10 auto & manually adjustable air suspension
    If yer gonna dream ....
    #23 hill, Aug 21, 2018
  4. SteveMucc
    SteveMucc Active Member
    391
    268
    Kentucky
    I have a Lowance chartplotter/fishfinder on my boat. The screen is readable even in direct sunlight and there is never any reflection off of it (and out on the lake you have a lot of chances for direct glare). it's not polarized so I can read it with any sunglasses I choose to wear.
  5. SteveMucc
    391
    268
    Kentucky
    I don't see any reason they couldn't be combined. the Atkinson cycle, in simple terms, means that the compression and expansion strokes are of different volumes (this used to be done with linkages, but now they just keep the intake open and blow out some of the mixture during the compression stage and simulate the Atkinson cycle).
  6. Tideland Prius
    16,557
    You're right. But the reason was cost (and weight as secondary consideration) - they wanted to take advantage of using the same parts as the regular Prius to keep costs down for the plug-in. This is why there's a one-way clutch and why they used MG1 as part of the "dual motor" setup, instead of slapping on a larger MG2.
    I was talking through a translator for the Gen 4/Prime engineer. (I was at the Prime event at NYC)
  7. Spidey71
    Spidey71 Member
    60
    49
    Alberta, Canada
    2018 Prius Prime
    - A male block heater outlet located in the charge port bay for those of us in cold climates. That way you don't have one cord sticking out of each end of the car.
    - Free software upgrades for the Nav. system. If my $170 Garmin GPS can support this, then so can Toyota (although Apple/Android auto would be even better).
    - The ability to manually turn off or limit number of "reverse gear beeps"
  8. The Electric Me
    9,083
    5,801
    Well then my question would become is the engine in the Camry Hybrid an Atkinson cycle engine?
    Because I assume the Dynamic Force Engine in the Toyota Corolla is NOT an Atkinson cycle engine.
    Never mind...
    I got off my butt and did some digging myself, to find Toyota's Dynamic Force Engines do already exist in Non-Hybrid and Hybrid engine forms.
    So I guess I agree. Unless Toyota was just vetting the system, in the real world, it should be an evolutionary step for Prius.
  9. Trollbait
    12,539
    The dynamic Force engines are Toyota's newest family of engines with the hybrid port and direct inject, plus their more advanced valve timing. The Prius line and other models should see it installed with their next generation. But there is markets and price points to consider. The Toyota Yaris still has a 4 speed automatic to keep it cheap in the US, and the Valvematic valve timing system is only available on the high end Corolla engine in the US, while being standard in Europe.
    The main difference between Otto and modern Atkinson cycles is in the valve timing. There are traditional cars with engines on the road that can adjust their valve timing to almost be running as a hybrid Atkinson under light loads. An engine for the hybrid may have its 'compression' ratio a little higher than the non-hybrid version to make its Atkinson cycle more efficient, but this and valve changes are minor for a major engine company.
    PlugmeInplz and The Electric Me like this.
  10. SteveMucc
    391
    268
    Kentucky
    One other thing to consider... Atkinson cycle engines simulate a smaller displacement engine than an otto cycle engine. Therefore you get less power out of an Atkinson cycle engine than you would out of an otto cycle of the same displacement (you extract more power from the amount of fuel used but since you're using less of the compression cycle you end up using less fuel which is why hybrids like it).
  11. Tideland Prius
    16,557
    It's dealer customisable to one-beep if you wish.
  12. Spidey71
    Spidey71 Member
    60
    49
    Alberta, Canada
    2018 Prius Prime
    Thanks! Do you know if they charge for that if we request it during one of our regular services?
  13. frodoz737
    frodoz737 Top Wrench
    4,699
    2,497
    33
    1. Better looking body!
    2. Spare!
  14. hill
    8,805
    a block heater cord? It's not even needed! Some plugins actually use the J plug to pull power to heat/cool their motors AND packs/inverters. Like i mentioned above - if you're going to dream .....
  15. Spidey71
    Spidey71 Member
    60
    49
    Alberta, Canada
    2018 Prius Prime
    Now THAT, I can get behind! Even better!
    hill likes this.
  16. dame94
    dame94 Junior Member
    32
    Brentwoodish, California lol
    2018 Prius Prime
    Solar roof
    10% more battery range
    All black interior
    A REAL leather option (or change the current stuff to something more durable)
    I’m starting to really reach.... all I know is I’m happy with my prime advanced and if they put a solar roof on the next one.... I’ll trade in my 14’ Prius C in a heartbeat.
  17. PlugmeInplz
    PlugmeInplz New Member
    22
    24
    LA
    2013 Prius Plug-in
    1) Apple Car play
    2) Add some buttons to the info screen dedicated to climate control and knobs for volume
    3) Update the screen so it responds quicker and modernize the UI. Glass screen.
    4) 16KWH battery mounted under the floor.
    * 7.6 KWH onboard charger - Max for public L2 chargers.
    * Give the electric motor more power.
    5) 5th seat. ;)
    6) Liquid cooled battery with tech to use exhaust heat to warm the battery.
    7) Subwoofers under the driver and passenger seats.
    8) Copy Volts oil monitoring system. If I drive 90% EV I want to change the oil at 7500 miles of gas use
    9) Optimize the ICE to minimize cycle start.
    * An secondary electric oil pump to pre-lub before engine starts and to cycle engine without gas.
    * The electric motor can turn over the pistons and valve train with out gas while your plugged in.
    10) Center console and trunk AC outlet for laptops. With charge mode you have a mobile power generator.
    #37 PlugmeInplz, Aug 24, 2018
  18. PlugmeInplz
    22
    24
    LA
    2013 Prius Plug-in
    If toyo reads this it will save them the time to translate.:whistle:
    1)Apple Car play。
    2)気候制御専用の情報画面にいくつかのボタンを追加し、ボリューム用のノブ
    3)画面を更新して、より迅速に応答し、UIを近代化するようにします。ガラススクリーン。
    4)床の下に16KWHバッテリーを搭載。
    * 7.6 KWH搭載充電器 - パブリックL2充電器の最大値。
    *電動モーターの動力を増やす。
    5)5番目のシート。 ;)
    6)バッテリーを暖めるために排気熱を使用する技術を備えた液体冷却バッテリー。
    7)運転席および助手席のサブウーファー。
    8)コピーボルトオイル監視システム。私が90%のEVを運転した場合、7500マイルのガス使用量でオイルを交換したい
    9)サイクル開始を最小にするようにICEを最適化する。
    *エンジンの始動前に予備潤滑を行い、ガスを使わずにエンジンをサイクルさせる二次電動オイルポンプ。
    *電気モーターは、プラグインしている間にピストンとバルブトレインを排気ガスで裏返すことができます。
    10)ラップトップ用センターコンソールおよびトランクACコンセント。充電モードでは、モバイル発電機があります。
    benagi, dame94 and Spidey71 like this.
  19. PlugmeInplz
    22
    24
    LA
    2013 Prius Plug-in
    Also beyond the Prius. Take the plug in tech and put it in a Tacoma pickup truck, Sporty Supra / 86, SUV / Crossover.
    Can you imagine a 2JZ hybrid motor with electric motors driving the front and boosting the rear. The torque of a electric with the high speed power of an ICE engine.
    Toyota could redeem their hesitation for waiting for the electric market to evolve.
  20. 2015BlizzardPriusFour
    2015BlizzardPriusFour Active Member
    171
    142
    Central Valley CA
    You could also look into Carista usb dongle and app. I was able to modify a few settings using it.
    iPad ?
