Let's talk Prime tire/rim mods
Discussion in 'Prime Accessories and Modifications' started by 4rpr15, Sep 17, 2017.
  1. MSAGRO
    MSAGRO 2010 Prius Five with Advanced Technology Package
    259
    227
    Portland Oregon
    Thanks. They are applying 3M 1080 gloss black vinyl. Hopefully this is a good brand that will endure Oregon weather as well as carwashes. Any experience with the 3M products?
  2. PHV PLS
    PHV PLS Member
    157
    81
    2017 Prius PHV
    3M is the best product! I have it on my tint and vinyl. Always had 3M last a very long time! The roof will last around 4 years of you take good care of it. Vinyl isn’t a perminate solution.. only tempary just remember that . That what paint is for :eek:
    MSAGRO likes this.
  3. MSAGRO
    259
    227
    Portland Oregon
    Did mine this week!
    #23 MSAGRO, Apr 5, 2018
  4. PHV PLS
    PHV PLS Member
    157
    81
    2017 Prius PHV
    Oooh looks clean!!! I like!
    What kind of material? (y)
  5. PvPDX
    PvPDX Junior Member
    58
    Portland Oregon
    2015 Prius v wagon
  6. MSAGRO
    259
    227
    Portland Oregon
    A5C5DF85-A0A1-4E43-8C1C-F557BD60FA71.jpeg Kolor Werx in N Portland.
    3M 1080 satin black vinyl.
    Kevin does great work at a great price.
    PvPDX and PHV PLS like this.
  7. Krzysiek_KTA
    Krzysiek_KTA Active Member
    159
    125
    Houston
    I swapped to 16" rims with 205/55R16 RunFlat summer tires and experienced 10-12% drop in EV range ( 4.4-4.5KWh/mile vs. 5.0-5.2 KWh/mile on stock wheels) on the same commute route and same driving style.
    Nevertheless the car handles way way better and gives 'incentives' to drive more aggressively so.... EV range drops further but more fun to drive.
    Hope that helps.
    Kris
  8. Rob43
    Rob43 Senior Member
    1,373
    1,050
    VA, BMW Race Car, BMW R1200R, BMW 330Ci, Ford F350
    2013 Prius v wagon
    Your 10-12% drop in EV range is MUCH more a fact of RunFlat added weight than anything else. Using a RunFlat on a PP is a mistake based on the needed *steel cord*, the needed steel cord adds a lot of unsprung weight.
    Here's an example of the same two Nokian 205/55-16 tires, one is a regular tire & the other is a RunFlat; Look At The Whopping Weight Difference Of 7.6 lbs between them. So if you had a new aftermarket 16" wheel at 17 lbs & the above regular Nokian at 17.6 lbs, you'd be at a very good weight of 34.6 lbs, now if you add the RunFlat you're at 42.2 lbs which is crazy heavy on a PP.
    Rob43
    PvPDX likes this.
