Let's try replacing the 12v battery with a much smaller, lighter one
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Myself248, Jul 26, 2020.
  1. Mendel Leisk
    42,369
    There are (cheaper) aftermarket equivalent batteries. Sometimes the cases even look identical; makes you wonder if it’s the same battery, just different badge. Or at least adhering to identical spec’s.
    Up here, for 3rd gen at least, Canadian Tire has one that’s completely compatible and significantly cheaper. Still sand-pounding expensive compared to just a few years back though; all the more reason to comparison shop.
    C Wagner likes this.
  2. C Wagner
    C Wagner Member
    183
    60
    Boston
    Ha! No, I am still functioning with an unchanged but failing 12v aux battery. Due to the desulfator, it may be improving, or it may be just continuing to survive. Overnight voltage around freezing is about 11.7-12.1v cold when the start button is pressed to orange before I engage the HV battery to charge the aux to 13.8.
    I've so far gone to ogle the 35 AH U1 battery (tiny!) and I've ordered a U1 to SAE adapter/converter from the Bay of Es. Down here in the lower 48, Harborfreight sells them now for about $72 non-Loonies minus a 20 or 30% coupon, usually obtainable. My Gen II MPG seems pretty low, despite pumping the tires up, the replaced HV battery, fluids changed, so I'm looking at the new battery as my personal savior - along with an eventual new PCV, cleaned spark plugs and valve adjustment in the warmer weather -- March...
    I took my HV battery apart when I bought the car (for $100) and ultimately had to replace 4 modules and recondition/balance the rest. That fixed pack got a good grade from Dr Prius, so I hope it will last me at least several years. If not, I wrote the Wiki partially to remind myself how to take it apart again. Reconditioning and balancing takes a long time, but removal-replace and balance only takes about 4 hours, especially if you've done it before, I guess.
    #42 C Wagner, Feb 5, 2021
  3. Myself248
    Myself248 Junior Member
    32
    Royal Oak, MI
    It's a year on and it hasn't left me stranded, but in subzero weather it clearly struggles with the brake booster pump, which runs as soon as you open the door rather than waiting for READY mode. Since my 18AH is nice and new, it hasn't failed to meet this challenge yet, but I'm sure that'll come at a young-ish age given how undersized it is. I would not recommend a battery this small to folks who live in cold climates. I guess that's the outcome of my experiment. Sounds like others have found 35AH to be more than adequate, but 18 is only sane if your car never gets below freezing. I'm in Michigan, but then, I've never been called sane...
    (If the brake booster would wait until the DCDC comes up, the car would be 100% fine with an even smaller and thus even lighter 12v battery. I guess they really, really prioritize having brake vacuum available the instant the powertrain comes up. Which I guess I understand. Sucks for lightweighting, though.)
    That being said, I think 18+18 with an isolator is gonna be better than a monolithic 35 or whatever, because it also gives self-rescue ability in the event of leaving the headlights on, which will kill a battery of any size. I haven't done that recently but I did it a few times back when I had the original battery, and I'm sure it'll happen again someday. I already keep a lipo jumpstarter in the seatback pocket, but a start-assist pushbutton would be even cooler. I haven't found this particularly urgent though, so the isolator relay is still sitting here in a box...
    The voltage on the 12v rail should be maintained by the DCDC the entire time the car is in READY, regardless of the capacity of the battery. If the battery is in a discharging condition such that its voltage could decline faster because the battery is smaller, then by definition the car is not in READY and won't be starting the ICE as a result.
    Do I misunderstand something?
  4. ASRDogman
    ASRDogman Senior Member
    8,069
    4,092
    If you have to have two batteries, you double the weight, and only get 1ah more then the battery that should be in it.
    Seems like a waste of time and effort.... And never knowing when it will fail.
    Jump packs are small and $20, more than enough for the Prius.
    C Wagner and Grit like this.
  5. ChapmanF
    19,050
    Concur with all of that, except for the word 'vacuum': it's a pressure pump for brake fluid, as no vacuum is used in this brake system.
  6. dbstoo
    dbstoo Senior Member
    1,397
    753
    Near Silicon Valley
    2024 Prius Prime
    XSE Premium
    I did not read it all, but as I recall, the 12V battery is also used to provide the brakes, steering, lights, etc in an emergency. The way that AGM goes from usable to dead (in my UPS use) makes them less desirable to me.
    Dan
  7. PriusCamper
    PriusCamper Senior Member
    13,472
    5,440
    Pacific Northwest, USA
    Thanks for following up on your research into small 12v... That booster pump is something we didn't consider in our previous discussion. And though it would probably be fine for it not to work until the car is in ready mode, it's probably bad to be sending a weak voltage signal to the booster pump for an extended period of time.
    #47 PriusCamper, Jul 17, 2021
  8. C Wagner
    C Wagner Member
    183
    60
    Boston
    Thanks, folks, for the discussion above.
    I just wanted to update you on my replacement for the 2012 OEM 45AH Toyota battery in my 2004 SKS Prius. In the end, I bought a Mighty Max 35 AH battery ( the capacity of the non SKS cars' OEM batteries in Gen II I believe). This was a $65ish purchase. I was careful to get a battery with left side positive terminals, but there is the issue of the car's Japanese domestic market style terminals.
    I got around the battery/terminal incompatibility by first using an adapter to go from the Might Max battery U1 tab terminals to SAE ($10 on Ebay) and then I bought a replacement bolt-in SAE connector for the car-side connector (hard to find, I used Installation Kit for Optima battery in Prius). The result is that the car now has a female SAE connection and the small 35AH U1 battery has a male SAE connector.
    There was much gnashing of teeth over the lack of a vent on the new battery, but other commenters on PC have said long term standard usage of similar unvented AGM batteries didn't result in any bad situations. Someday, I may carefully drill a hole in the top cap area of the new battery to allow the batteries top 6 port holes (sealed at the factory) to vent to the prius rubber vent tube.
    The size of a 35AH battery is smaller in all dimensions than OEM, so to safely fasten it in place, you'll need to insert something non-metallic to hold the battery securely under the battery hold down.
    So, long story short, how has it been with a 35AH AGM battery instead of the 45 AH OEM battery? Answer: It's been good to great. I've been away from the car for two weeks and found the battery could still start the car (and wasn't down to a 'shockingly' (pun) low voltage). The car's MPG went up after replacing the tired sulfated OEM battery, so I'm very glad I did this cheap replacement.
    Epilogue: I didn't need to hand over my OEM tired battery, so I hooked it up to my trickle charger/desulfator (a 90s Battery Minder Plus). After a couple of months of trickle/desulfation, the sad battery now reads 80% healthy; 'good' battery on my battery load tester, a TopDon AB101 model. 45AH AGM batteries are awesome. I'm thinking what to do with my now extra, mostly healthy old 2012 battery...
    One thing I won't be doing is putting the OEM battery back in the car; I'm quite happy with the 35AH substitution.
    PriusCamper likes this.
  9. PriusCamper
    13,472
    5,440
    Good for you for buying a 35amp-hour for $65 that most people on here pay $300 for because auto parts stores and stealerships don't price 12v reasonably.
    Though I must say, I'm sticking with my 55amp-hour 12v I bought for a $100 on my drive home from christmas in 2012. That 12v has yet to fail me!
  10. C Wagner
    C Wagner Member
    183
    60
    Boston
    10 years on a lead-acid battery is very laudable. Congratulations! I have only achieved that long-term ownership when cars have desulfating technology (prius?) or when I have the battery attached 24/7 to a very gentle trickle, like a small solar panel.
    Comicly, my 35AH battery HAS failed me since installation. Even though I charged it up to 100%ish, a few weeks after new receipt with initial full charge up, I foolishly left the car in "on but not READY" mode and worked on the speakers for a few hours. Just leaving it like that half a day killed (down to 7v under load!) the battery. I immediately noticed it (at the end of my 5 hours work!) and charged the battery up to full capacity and it's been fine. I love AGM batteries. Not happy with being run down, but a little less angry than standard wet/plate lead acid!
  11. Myself248
    32
    Royal Oak, MI
    Time for another update.
    So, shortly after that post, I did get the isolator relay hooked up. Two 18AH batteries, with a Victron Orion between 'em. One tied to the vehicle, the other purely as backup. The Orion would connect them whenever either one was above 13.5-ish volts meaning there's a charging source somewhere, then isolate them whenever their combined voltage fell below 13.0-ish meaning they're no longer charging. (It's more complicated than that involving time-constants, but you get the gist.) And, the goal of the whole thing, was a self-jump-start button that would force-combine the batteries, so I could self-recover from a headlights-left-on situation without having to drag out the lithium of dubious provenance.
    It all worked beautifully on the testbench, but once in the car it was awful. I had failed to consider the idle draw from the Orion. Theoretically it should be quite low, since the relay coil current only applies when there's a charging source, and the rest of the time could be a very low-power state in the microcontroller indeed. Theoretically, but evidently Victron never bothered to optimize it, maybe because it's usually deployed on giant marine battery banks where a few mA is inconsequential? A rare disappointment from Victron! Anyway, this flattened both batteries if I left the car sitting for a week or two, which is a pretty frequent thing now that I'm mostly working from home.
    Someday I'll engineer my own isolation relay with better idle power, because that's just unnecessarily disappointing, and I actually have several applications where that could be useful. But today is not that day.
    So I went with plan C, which is simply putting both 18AH batteries in simple parallel to make an effective 36AH battery. This is basically the same capacity as the original, but $70 instead of $240. And very little work, if I'd started there in the first place. These have actually been in place for about 3 years (wow, time flies!) and they're fine. I could still leave myself stranded if I left the lights on again so it's not perfect, just like the OEM battery, but now that I know how to defeat the lights' auto-shutoff, I also know how to avoid doing that, and I've been fine.
    Now, based on the history of this thread, someone very smug and very very very smart is gonna have a problem with me having tried all this out and documented it, because how dare I explore something I'm curious about and publish my results so others can learn some gotchas without wasting their own time and money. And they're entitled to their opinion, and I wish them well, but I learned something and had fun and didn't hurt anyone. And they probably better ignore this thread because I'm not done experimenting yet! Aw yeah, I own a thing and I'm tinkering with it. The horror!
  12. ASRDogman
    8,069
    4,092
    In theory, lot's of things work. But in the real world........ That's why their are prototypes...
    I know there's a device for two batteries, that will cut off the one that gets low and switch over
    to the good one. And when it gets low, it will shut off. And will charge accoringly.
    Since you don't drive much anylonger, why not use a solar charger? Just get one that is a
    high enough amperage to keep the battery charged.
    Or put a switch up front that attaches to a relay for a second battery that connects to the
    low/dead battery so you can start the car. The switch can be a push to connect, and when you
    release it, it disconnects.
  13. PriusCamper
    13,472
    5,440
    Back in my camper van conversion days in early 90's in our shop for custom VW campers we had a device that did this that we installed and referred to it as an isolator. It would not just do the switching you described but also the charging too.
