Leviton Charging Station
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by JMD, Dec 7, 2012.
  1. -1-
    -1- Don
    1,254
    439
    Chester, Virginia
    2024 Prius Prime
    Thanks for the information. That must be an electrician inside tip. I did mark the front of the receptacle "240v".
  2. ny_rob
    ny_rob Senior Member
    1,968
    813
    L.I.- NY
    He has an electricians license, he said "it's code" so I did it to my setup just in case :)
  3. Francos
    Francos Member
    118
    How much does it usually cost to hire an electrician to install the 220V wire (socket) for the station? The Fed 30% tax credit lasts through end of the year if not extended.
  4. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    The major part of the expense is running the cable from the breaker panel to the outlet location. This is going to vary wildly. Originally, I wanted it on the left side of my driveway, which would have meant running conduit underground, pouring concrete for a post, etc. I finally opted to simply install the outlet on the side of my house.
    A long installation run increases the cost of the cable, and potentially adds cost for metal conduit and labor. So there is no fixed price. I did the whole thing myself; it's not very difficult, unless you're running cable where it doesn't want to go.
    When I installed mine, I saw that the cost of the Romex cable was pretty significant at 50-100 foot distances, and heavier gauge cable costs at least double AND it's a lot harder to work with. Compare the thin cable and connector of the Toyota-supplied EVSE to a public charger. The public charger cable is WAY thicker. Routing a 50' spool of thick cable through a wall or conduit is a lot harder than with thin cable.
  5. El Dobro
    El Dobro A Member
    7,102
    3,280
    I had some Amazon gift cards lying around, so I bought the Leviton Level 2 charger with the plug. The faster charging time comes in real handy.
    Rebound likes this.
  6. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    I got the Leviton EVB22-3PT Evr-Green 160 3.8kW unit from Amazon ($750+ free ship). I installed it myself for about $30 in materials since it was mounted right next to the sub-panel in my garage.
    NOTE: you don't necessarily need the additional $70 mounting kit that is highly suggested by the manufacturer.
    Hi Burrito! likes this.
  7. El Dobro
    El Dobro A Member
    7,102
    3,280
    I didn't buy the mounting kit either. I just used the hole in the back of the thing.
  8. fotomoto
    5,639
    3,815
    So. Texas
    ZZZackly. I also added a hanger bolt and wing nut to the bottom mount:
    so mine is easily and quickly removable if I want to take it with me.
