Lexus Credit Card Smart Key
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Ken Blake, Aug 28, 2013.
  1. Ken Blake
    Ken Blake Active Member
    351
    180
    Portland, Oregon
    My ordinary keyfob is a 14ACX. The card type 14AEB apparently also works.
    Lexus has had the center cut keys from the beginning, so I am simply ordering a blank mechanical key from the electronic parts catalog, which I will have cut to my key code. There are two places nearby that can cut these, or there is also a guy right here on PC that bought a cutter and is cutting keys for people.
    You're welcome. I don't know, but I doubt it. In order to program, the Techstream needs to be connected to the car, and in my case, it also performed some kind of unrelated test, which would have required a connection to Toyota/TIS. It would not allow my tech to do anything, until he permitted it to run the test.
    #21 Ken Blake, Sep 2, 2013
    RobH likes this.
  2. RobH
    RobH Senior Member
    2,385
    991
    70
    Sunnyvale, California
    Interesting. That would seem to say that other 14AEB keyfobs would work on Prius that come with 14ACX.
    There are at least 2 shapes of Lexus center cut keys, neither of which match the Prius center cut key. The newest Lexus key is cut on one side only, with the other side a full cutout. It also is cut with a smaller diameter cutter than the old style. The Prius center cut key has the 4 outside corners grooved, unlike the Lexus that is just square cut.
    I can't even insert a Prius blank into a Lexus CT200h lock cylinder. Could be the hole in the end of the Prius key, or maybe the edge treatment.
    Let us know how the mechanical key cutting goes. I predict a continuing saga...
  3. Ken Blake
    351
    180
    Portland, Oregon
    Good to know! I will have to compare the blank to one of my emergency keys before any cutting occurs. Even at my cost, it's almost $40 for the blank.
  4. DaneH5
    DaneH5 Member
    464
    60
    Pinellas, Florida
    So where has this ended up?
  5. Ken Blake
    351
    180
    Portland, Oregon
    I had a local locksmith make a copy of my factory emergency key, which I keep on the car in a Hide-A-Key box. I tested the credit card key by removing the battery and pressing the start button with it. The car started, so the NFC feature is also compatible with the Prius.
    -Rozi- likes this.
  6. DaneH5
    DaneH5 Member
    464
    60
    Pinellas, Florida
    Any info on credit card key?
  7. bisco
    52,812
    yes, you can buy the lexus credit card key and have it programmed for your prius.
  8. DaneH5
    DaneH5 Member
    464
    60
    Pinellas, Florida
    Unless I missed it is there a part number or something for the card?
  9. bisco
    52,812
    yes, in the first post.
    Ken Blake likes this.
  10. CTorPrius?
    CTorPrius? Member
    100
    16
    Wilsonville, OR
    Can you suggest a locksmith to program card keys as well?
  11. Ken Blake
    351
    180
    Portland, Oregon
    As far as I know, only a Toyota or Lexus dealer can program the keys.
  12. CTorPrius?
    CTorPrius? Member
    100
    16
    Wilsonville, OR
    Would Toyota program a lexus key? I'm guessing, it's probably cheaper to go to Toyota to get it done.
  13. Ken Blake
    351
    180
    Portland, Oregon
    It varies by dealer. Some dealers will even add key for no charge, although that is rare.
  14. CTorPrius?
    CTorPrius? Member
    100
    16
    Wilsonville, OR
    I just spoke with some dealers in my area and they are quoting $55-$60 for reprogramming a key. Lexus wanted 3x as much! *yikes*
  15. DaneH5
    DaneH5 Member
    464
    60
    Pinellas, Florida
    Probably use techstream to program.
  16. Ken Blake
    351
    180
    Portland, Oregon
    I didn't notice that you're here in Oregon. If you're willing to make a trip to Hillsboro, Royal Moore Toyota will probably do it for free, if you go in during normal business hours. (M-F, 8-5).
  17. tbuckler
    tbuckler Junior Member
    Chicago, IL
    Sorry to raise an old thread but does anyone have an idea if this Lexus card key would work with a 2012 Camry that uses a Smart Key?
  18. RobH
    RobH Senior Member
    2,385
    991
    70
    Keyfob types are identified with a number like 14ACX. Look on the Camry keyfob for this number. If they match, it probably will work. I really doubt that the mechanical key in the Lexus card is going to work.
    I'm using a Prius keyfob with my wife's Lexus CT200h. The cases are different, but the circuit boards inside them are identical. The Prius mechanical key is different from a Lexus mechanical key.
    You're wandering in poorly charted waters. You may want to verify that you can return the key if it doesn't work.
  19. Ken Blake
    351
    180
    Portland, Oregon
    As posted above: My ordinary keyfob is a 14ACX. The card type 14AEB also works, since that is what is marked on the Lexus Credit Card key.
    The mechanical key will NOT work.
  20. tbuckler
    Chicago, IL
    Thanks guys, haven't yet bought a Camry or Prius but compiling pros/cons. The Prius I'm interested in uses a 14ACX fob but the Camry does not so that's definitely a plus for the Prius.
