LF door weatherstrip fail. How to replace and p/n?
Discussion in 'Gen 2 Prius Main Forum' started by egg_salad, Feb 10, 2020.
  1. egg_salad
    egg_salad Active Member
    545
    426
    Las Vegas, NV
    It's an '08, if that matters.
    I've just now discovered that the outer window seal on the drivers door has failed; the rubber has split.
    Drilling through the parts lookup, it appears what I need is:
    7572047010
    Door Window Belt Weatherstrip (Left, Front)
    #1 can someone verify that I'm looking at the right p/n?
    #2 anyone have any tips at changing this part?
    Thanks.
  2. Elektroingenieur
    2,515
    3,284
    Three Touring
  3. egg_salad
    545
    426
    Las Vegas, NV
    That's an old thread, still useful. I note that the current MSRP is 50% higher than what's quoted in the thread. Nothing gets any cheaper!
    Ah yes - found it, thanks, under section ED-20. Looks fairly straightforward. Thanks for your help.
    Elektroingenieur likes this.
  4. egg_salad
    545
    426
    Las Vegas, NV
    Job done. Some notes for future readers:
    I was somewhat surprised my local dealer had the part on the shelf. I was entirely unsurprised that the parts guy wanted to charge me 10% OVER list price. He ever so graciously agreed to match list price. How thoughtful.
    As for methodology... the method listed in the manual is... fine. I suspect it is written that way so a technician could remove the part in a non-destructive way - but I can't think of a reason one would need to remove it if it wasn't being replaced.
    It's a lot faster to remove it in a destructive fashion. Pop up the rear edge of the molding with a nylon trim tool and just yank. The whole piece just popped right off, in an admittedly highly destructive fashion, but so what?
    End-to-end, including removing and replacing the inner door panel, would have taken 25 minutes. Except that upon disassembly I discovered that the aftermarket tweeter mount that I created had failed, so I took some time to fix that, but that's entirely unrelated.
    valde3 likes this.
