LH Fog/Driving Lens Broken, Need To Replace, Or Upgrade
Discussion in 'Gen 3 Prius Accessories and Modifications' started by txtabby, Oct 26, 2016.
  1. Phatlife
    Phatlife Member
    107
    27
    New Jersey
    I'm thinking of going 3500k hid bulb, it should be yellow enough.. I ordered the Opti7 6000k led set for the h11's
    SM-G935T ?
  2. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    The LED H11 might not be optimal for lowbeam use. You would probably have been better off going with HID on the H11 lowbeams.
    Again, let us know how the LED H11 works out for you. Especially paying attention to beam pattern and throw (how far the light goes forward down the road) from the lights.
    Phatlife likes this.
  3. Xterra72
    Xterra72 Senior Member
    1,437
    1,684
    That's too bad. Sorry.
  4. Phatlife
    Phatlife Member
    107
    27
    New Jersey
    why it's bad? the light is not scattered like the useless $ 300 oem's. lord of people have complained oem setup is ineffective in bad climates.
    SM-G935T ?
  5. xliderider
    8,140
    3,280
    Honolulu, HI
    You misunderstood the post. It's too bad the laminate film won't go on the projector lenses...
    On the other hand, the LEDs you purchased probably won't have a very good beam pattern due to the design of the LEDs.
    A halogen bulb and an HID bulb both have pretty much a single point light source, whereas the LED gives off light from two sides, with a circuit board blocking the light from the other side.
  6. Phatlife
    Phatlife Member
    107
    27
    New Jersey
    led will go in low beam, anything is better than halogen.. I have optilux by Hella in my camry, it's pretty good . for a halogen in the factory fog set. 123_1.jpeg
    SM-G935T ?
  7. Phatlife
    Phatlife Member
    107
    27
    New Jersey
    so do you recommend the 3500k hid from xenon depot our the fog set?
    SM-G935T ?
  8. xliderider
    8,140
    3,280
    Honolulu, HI
    No, IMO HID is overkill for foglights. Here's my Camry with 4300K HID in the lowbeams and 2500K Nokya halogens in the projector foglights:
  9. xliderider
    8,140
    3,280
    Honolulu, HI
    Different view:
  10. Phatlife
    Phatlife Member
    107
    27
    New Jersey
    I have the optilux on my camry with photo posted earlier
    SM-G935T ?
  11. xliderider
    8,140
    3,280
    Honolulu, HI
    Yeah, that looks good. No HID necessary in the foglights.
  12. Phatlife
    Phatlife Member
    107
    27
    New Jersey
    SM-G935T ?
  13. Phatlife
    Phatlife Member
    107
    27
    New Jersey
    I should stick to the optilux by Hella for the projector housing I purchased?
  14. txtabby
    txtabby 2011 Prius 4
    139
    Austin, TX
    I got the parts, but I saw a good how-to guide on removing (folding out of the way) the front underside cover to access the fog lights. Anyone have that guide? Thanks!
  15. Phatlife
    Phatlife Member
    107
    27
    New Jersey
    isn't that just about a couple of screws to take off the bottom cover? I just ordered the fog light grille.. I have to pop off the whole bumper.. going to take my time.. how hard is to wire the bad boy with the Toyota yaris harness kit?
    SM-G935T ?
  16. txtabby
    139
    Austin, TX
    Not that simple. You have to remove fasteners and screws from the bottom cover, and the fender shields(?), then fold it down. I don't know if I can do it with jackstands, since the instructions I saw here had photos of the car on a lift.
  17. xliderider
    8,140
    3,280
    Honolulu, HI
    You can definitely do it with jackstands.
  18. Phatlife
    Phatlife Member
    107
    27
    New Jersey
    anyone have the instructions?
    SM-G935T ?
  19. xliderider
    8,140
    3,280
    Honolulu, HI
    Xterra72 likes this.
  20. Phatlife
    Phatlife Member
    107
    27
    New Jersey
    20161107_193741.jpeg 20161107_193028.jpeg 20161107_193720.jpeg 20161107_193712.jpeg
    My Opt7 low beam leds.. 1st day.. not far as hid , but better than factory halogens..
    SM-G935T ?
