LiBSU - Redesigning the "Battery Support Unit" to Support Lithium
Discussion in 'Gen 3 Prius Technical Discussion' started by mudder, Jun 7, 2024.
  1. NHP10L
    NHP10L New Member
    Calgary
    So, is the inverter enforcing limits based on HV readings or its own readings?
    Would be fun if the inverter blindly trusts and use the HV readings ;)
    That's only for my Prius C tho, not sure a regular Prius behaves differently.
    I also recall that you would like the LiBSU to work for any chemistry, while making it non user interactable. Any thoughts on the implementation yet?
  2. ChapmanF
    18,910
    There's a middleman in the story being left unnamed: in a gen 3 Prius, the BSU is really talking to the power management control ECU, under the dash. That ECU drives most 'macro' behaviors here being attributed to the inverter. Most of the comments above about what the inverter does or what the inverter cares about are really about the power management control ECU.
    (In fact, the power management control ECU is really just talking to another ECU, the MG ECU that's inside the inverter enclosure. The MG ECU is what directly controls the inverter switching, and all the 'micro' details like synchronizing to the MG rotors' rotational position.)
    mudder, hurricos and Brian1954 like this.
  3. NHP10L
    NHP10L New Member
    Calgary
    Would be great if you can share any diagrams, or link us to posts about this in detail!
  4. ChapmanF
    18,910
      File size:
      7.5 KB
    NHP10L likes this.
  5. mudder
    mudder Active Member
    293
    401
    Chattanooga, TN
    I don't know (yet).
    What do you mean by "non user interactable"?
    Correct.
    For now, I've abstracted the rest of the Toyota system, treating it all as a black box, because that's all I need to develop LiBSU so far. LiBSU could be talking to the fuel pump – which then relayed controls to the head lights, which forwarded them to the inverter – and it wouldn't make any difference for LiBSU development purposes. Modularity and black boxes are awesome concepts. I can peel back the non-BSU architecture later, if needed.
    Noted.
    Noted.
    Noted.
  6. NHP10L
    NHP10L New Member
    Calgary
    I should rephrase my question, how do I tell LiBSU my battery chemistry and battery capacity?
  7. Headgasket
    Headgasket New Member
    SLC, UT
    New to the site but not new to the Prius! I'll be following this project it looks pretty sweet. This stuff looks like the reason I dropped out of electrical engineering classes LOL.
    mudder likes this.
  8. mudder
    293
    401
    Chattanooga, TN
    Update on my previous video (post#73), wherein I stated:
    "I haven't used Microchip's MPLAB enough yet to have a negative opinion, but I've used it enough to know I'll probably have a negative opinion":
    I've used MPLAB enough now to verify it is in fact a steaming pile of fail (for more reasons than the one issue I mention next).
    I spent yesterday and this afternoon troubleshooting why none of my analog inputs worked correctly. ChatGPT was useless as a troubleshooting tool, confidently hallucinating some of the worst debug code I've ever seen. At one point it was trying to get me to configure the ADC to run at 12 MHz (8x more than its max rated frequency). For some reason it kept confusing register names and values with other unknown MCUs. ChatGPT was truly a waste of time troubleshooting this issue.
    I'll spare all the details, but the ultimate root cause was I had the wrong CPU configured (totally my mistake). LiBSU uses the AVR64DB48, but I incorrectly selected AVR64DB64. Totally my fault, but somehow Microchip's official tool never bothered to tell me that the device IDs were different. It just uploaded the code blindly.
    Even with the incorrect part selected, the MCU worked for the most part. Over the past few days I've verified USARTs (including USB), timers, clock, GPIO, and pretty much all the digital stuff. No issues. However, the analog signals were wonky in really bizarre ways.
    The 3rd party programmer I purchased last week showed up today. I was excited because this tool allows me to ditch Microchip MPLAB entirely. I can now use GCC+avrDude to program the board directly. In doing so, it immediately identified the root cause:
    WARNING - ID read ('1E9617') does not match expected device id! ('1E9616')
    In plain English, this 3rd party tool is saying:
    "Hey dummy, you've got the wrong MCU selected"
    Unlike Microchip's native MPLAB programming environment, the 3rd party programming tool actually verifies the MCU's device ID matches the compiler settings. I'm really amazed I got this far with the wrong MCU selected... again, pretty much all the digital stuff works correctly.
    And what do you know, with the correct MCU selected the ADC works correctly. Crazy!
    #88 mudder, Dec 10, 2025
    Prius DIY nut and Corvairius like this.
  9. hurricos
    hurricos Junior Member
    72
    24
    Burlington, Vermont
    I, too, hate MPLAB. Want to share the new programmer?
    I admittedly really like my XGecu T48, but I do a lot of nonsense with DIPs and EEPROM programmable stuff, so.
    mjoo and mudder like this.
  10. mudder
    293
    401
    Chattanooga, TN
    HV-UPDI Friend...
    ...best $10 I spent this year. It worked immediately out of the box, which is more than I can say for the four different versions I attempted to build myself. I suspect the Arduino core was sniping my Uno-derived kludges, which was preventing the upload from succeeding. Redditors say the CH340 is the best SerialUPDI transceiver, but I didn't have one on hand... UPDI Friend uses CH340 and works great. Regardless, I don't care what the root cause was, as UPDI Friend solves the problem for the cost of lunch.
    #90 mudder, Dec 10, 2025
    mjoo and hurricos like this.
  11. mudder
    293
    401
    Chattanooga, TN
    LiBSU will support user-configurable:
    -Voc->SoC lookup table, and;
    -nominal pack capacity in mAh, and;
    -min/max allowed SoC.
    Thanks for your support.
    This isn't even the hard stuff... setting up the build environment is the gateway to the actual engineering work.
    Even having completed the coursework, EE is still black magic... it's all about keeping the magic smoke inside the chips.
    NHP10L, Headgasket and hurricos like this.
  12. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    MPLAB X is the main reason I tried to steer my company to using an ARM Cortex. Mplab X has gone downhill since at least around v 4 or 5. Have to reboot multiple times a day when debugging if using anything other than their latest debug tool, the ICD 5.
    ARM is way nicer, the IDEs aren't shit, the fast debug port and ETM allow you to view everything inside the chip at high speed without needing to compile the program in a debug mode.
    mudder and hurricos like this.
  13. mudder
    293
    401
    Chattanooga, TN
    I'm excited to one day get my feet wet with a Cortex M0. Kicking that can for now, since I successfully removed MPLAB from my build environment.
    No new updates today... spent it in South Carolina visiting an old friend.
    Prius DIY nut, Corvairius and mjoo like this.
  14. mudder
    293
    401
    Chattanooga, TN
    Mr. F likes this.
  15. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
  16. mudder
    293
    401
    Chattanooga, TN
    It's been a while since I've used ADUM isolators... probably on the PXIe-2514 circa 2010 or so. While they're good at isolating signals, they do so entirely within a single die... in this application I need isolation between modules.
    I considered building a capacitor with one large copper trace on each sandwiched PCB. Unfortunately FR4's dielectric constant is very low (i.e. 4), so you just can't get enough capacitance to AC-couple signals... it's only ~10 pF/cm^2 with 300 um spacing. I need 10000x more capacitance than that for this application.
    I'm going with pogo pins between modules.
  17. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    Why does the inductor/capacitor need to exist at the interface? Why not put it on the circuit board?
    SM-A536V ?
  18. mudder
    293
    401
    Chattanooga, TN
    The goal with that side quest was to remove the serial communication pins that connect between each module.
  19. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    Yes, I know the quest. My point is I bet it's easily solvable. Maybe some cut tin sheet metal for your contacts on the sides of each module. Like cellphone battery contacts but probably easier since the modules are compressed together.
    SM-A536V ?
    #99 mjoo, Dec 22, 2025
  20. Pomegranate
    Pomegranate Junior Member
    UK
    Super excited by this project. I currently have a Gen2 Prius and I have one of the old Enginer PHEV conversion kits with a ~20 year old 4kWh heavy LFP battery. I bought it cheap as the bottom cell has been killed by being over-discharged while the BMS was powered from it. I've never got around to installing it in my Prius: ~10 miles of PHEV range wasn't really worth the effort, and the OEM battery is working fine (172K miles).
    Now looking for a bigger car and the 2006-2019 Estima minivan tops the list. The problem is that the battery lives between the front seats and is badly cooled so they tend to cook their batteries. As a JDM import there's no supply chain for new batteries ($2400 in Japan but shipping is difficult) and so we're left with ebay merchants reselling batteries from used vehicles, of dubious quality. It would be neat to do a PHEV conversion as there's a thirsty 2.4L engine but 105kW of all-wheel electric drive. However the Enginer way of topping up the SoC of the NiMH battery to keep it at ~70% SoC is going to be very hard on the NiMH battery (and the Enginer inverter from 48V LFP is only 5kW), so it would be better to replace it with a bigger pack.
    One request for the feature list... the Estima has a split pack, the bottom portion has 12 modules each being an 8S configuration of NiMH cells, and the top portion has 9 modules in a 12S configuration. That means the voltage taps are 9.6V apart for the bottom modules and 14.4V for the top modules. So please don't hardcode anything to assume that the modules are all the same configuration, as there are vehicles where that's not the case.
    (In the unlikely event you want an Estima BSU (89892-28010) to play with, I can ship you one)
