LiBSU - Redesigning the "Battery Support Unit" to Support Lithium
Discussion in 'Gen 3 Prius Technical Discussion' started by mudder, Jun 7, 2024.
  1. hurricos
    hurricos Junior Member
    74
    24
    Burlington, Vermont
    Yeah, the "Gen3 Prius" equivalent in Lexus world - RX450h and the 2012-2019 Highlander, for example - P/N 89892-48040 has even *less* real estate than 89892-47010/47020 (that is currently being designed around) does.
    All told: I would not expect LiBSU to *ever* cover 8-cell-style NiMH. There is not enough market, and not enough stuff in common. Or, rather, a future might exist where the guts of the LiBSU product boogy their way over to the "Gen3 Prius PHY" equivalent in 240-cell land, but I would not expect to find the LiBSU brand on them.
  2. mudder
    mudder Active Member
    305
    413
    Chattanooga, TN
    I agree that this is very unlikely to ever happen. Thanks for digging into the weeds so I don't have to. LiBSU is intended for use in vehicles originally containing Toyota's mass-market NiMH Blade modules.
    After several months, I finally got some sample BMS ICs. I had to sign an NDA to even get the datasheet. I don't understand why the (new) manufacturer requires such secrecy. They acquired the core technology by purchasing another existing company. They still sell the existing part numbers under the old company's brand without an NDA. However, their newer generation parts are under NDA, even though they're almost entirely identical. My NDA prevents me from even outlining the differences between parts. In the image below, I've even obscured the IC package markings to comply with the NDA.
    So then today I finally jumped through the hoops and received a few sample NDA parts...
    ...and the footprint is different from the footprint in the NDA datasheet!
    It's supposed to be LQFP, but instead it's LFCSP. In case you don't know the difference:
    -LQFP is 10x10 mm and has real, physical pins that you can solder to, whereas;
    -LFCSP is 7x7 mm and doesn't have pins, and is basically a chip-scale encapsulated die with bottom-mounted gold pads.
    It turns out they offer the part in both packages, but the NDA datasheet they sent me was for LQFP, whereas the parts they sent are LFCSP.
    For bringup testing (on just this one board), I was just barely able to kludge the 7x7 part onto the PCB's 10x10 pads:
    I have no idea if the pinouts are the same; haven't powered up the board yet. If they're different, I'll probably end up letting the magic smoke out. Wish me luck!
    Hoping I don't have to wait several more months to obtain the LQFP part. NDA parts are annoying.
    jungle, Stencil_Box and Corvairius like this.
  3. Stencil_Box
    Stencil_Box Junior Member
    Planet Earth
    Thanks for breaking it down for us laymen.
  4. coolchilli
    coolchilli New Member
    UK
    I can't believe you've found one of these in the UK! I've been looking for one for years... If you don't have a use for it - would you be willing to sell it to me?
    I've got 2 Gen2's both quite sick... one I'm hoping Mudder's BMS will enable me to get Sodium working safely, and the other I dream of making a PHEV...
  5. jungle
    jungle New Member
    Panama City, Panama
    Hey @mudder I know you've said it'll be ready when it's ready, and I respect that, but my battery just went kaput and I'm trying to decide whether to wait for LiBSU or just replace it with NiMH for now. I'm not in a huge rush since I have another vehicle (just way less efficient), so I'm genuinely open to waiting if the timeline makes sense.
    So my question is: if you had to assign a rough percentage to how complete the project is right now, what would you say?
    Also thank you for taking the time to work on this. I've been wanting to go the lithium route for a while, but everything I read made it clear it wasn't safe just yet. Mad respect for your work!
    Corvairius likes this.
  6. mudder
    305
    413
    Chattanooga, TN
    I don't have an ETD for the public product. You should get an OEM NiMH pack if you need a new battery now. Without a dedicated product manager, Pareto principle makes percentage estimation difficult.
    jungle likes this.
  7. James Analytic
    411
    63
    Michigan
    I've been compiling info regarding the 2012-2015 PHV since a friend got a 2014 PHV that was pretty much stuck with bad Brick C & D. (Has four 14 cell Bricks termed per Techstream). 56 cells total. Here is the link. Prius Plug In P1A00, P1A61, P1A64, P1A67, P301A, P314A, P31AB | PriusChat
    I envision using Prime cells in the future in one of the two HV packs that literally we just picked up in Chattanooga last weekend. Go figure. :)
    However, for my gen 2's and possibly the gen 3, would be nice to have more cost effective options to use those Panasonic Lithium NMC prismatic cells and/or a range of other cells.
    I am definitely willing to test as well if you need and I do have enough NMC cells, though still need to compress the bricks, drill out the rivets and determine if going to try to fit nuts welded on the end plates or use rivets again. Debating getting a PRIME pack next month just to have while they're seemingly cheap and I see some newer ones around locally. The 2017-2022 come with 96 cells FYI.
    Looking forward to reading more and updates.
    #127 James Analytic, May 27, 2026
  8. MN Driver
    MN Driver New Member
    Minneapolis, MN
    I've joined Prius chat, first post. Fellow owner of the 2000 Insight(qty 2).
    Here's some data I gathered from my 2007 Prius about how the car treats the battery and what voltage tolerances it works within.
    Background: This is data from a sick battery pack back in October 2025 when things were colder as well as from the pack when it was rebuilt with 9 modules from a junkyard pack(reinstalled 6/3/2026) where all of the replacements were better when performing both load testing and capacity than every single existing cell in the Prius. ..but the rest of the junkyard pack had problem cells within the module where they would all drop to 6.11v or less after 1Ah of discharge at only 10 amps. Worst module in the *current* pack is 2902mAh measured at a 10 amp discharge to a 5.4v termination so in my opinion it's still a rough pack but Dr. Prius thinks having less than a 3Ah pack means "Battery pack has esimated 92.89% capacity left, it is in new condition." ...IMHO, a bit of a junk tool that's a cludge to use but I imagine it's consistent enough for that one function where it has you aim for approx 6.5 amps from full and waits until the car fires up at what the car thinks is 40% SOC. My pack rebuild targeted trying to get the best IR modules to replace the worst IR modules("IR" in my case was determined by comparing voltage under load after pulling 1Ah and 2Ah out of the modules) and not care about capacity which is also what I did when rebuilding Insight packs, it seems to have brought a bunch of performance back to the Prius.
    My 2nd gen Prius data(per Dr. Prius, limited testing of only 3 different days(6/3/2026 and 2 days in October 2025):
    Lowest block voltage - 12.41v at 42% SOC drawing 104.1 amps with the temp sensors reading 93.9-98.8f, whole pack was 183.49v at the moment. That block has the smallest 2902mAh module(measured at 10 amps to 5.4v termination when rebuilding it), so it was hitting empty hard. ..and then it continued to discharge at a slightly lower amperage of 91.35 amps at 183.94v pack voltage with a 41% SOC where with the reduced current that block showed 12.94v. Battery thermistor temps 93.9-98.9v.
    Lowest pack voltage
    178.94v 121.79 amps 42.5% SOC, 93.9-98.8f. 6/3/2026.
    Highest pack and block voltage(same Dr. Prius screenshot)
    Highest pack voltage - 286.33v (/14=20.45v or 10.225v per module)
    Highest block voltage - 20.70v while the lowest was 20.10v
    This was at 59% SOC 53.94 amps, 52.6-53.9f in October 2025.
    Highest discharge amperage
    190.31v 143.93 amps 52.5% SOC 115.3-119.8f
    Highest charge amperage
    261.54v 94.37 amps 60% SOC 89.4-95.6f
    Conclusions based on the data:
    The 2nd gen Prius seems like it tries to keep the lowest pack voltage above 180v although it overshot to 178.94v.
    The car is okay with pushing to 286.33v during regen when the pack is lukecold, but I don't know what the software limits are.
    It let's the 2 module block level get down to 12.41v under a 104.1 amp load at 42% SOC, it seems to allow you to pound the pack, even near its 40% SOC cutoff.
    Apparently 119.8f still allows 143.93 amps discharge, which surprised me. I also saw 66.16 amps regen with the hottest thermistor at 121.f. I was cycling the pack pretty hard multiple times after putting the pack I rebuilt back in the car, so that's why it was hot.
    Even though this pack is not an awesome collection of modules and could be much better if I tore into a second junkyard pack during the rebuild, it seems like the 2nd Gen Prius will push more voltage per cell than the 1st gen Insight will and discharges with a slightly more conservative per cell value and the amperage it pounds the pack with in both directions is also impressive even at its software defined SOC extremes, these are very powerful NiMh packs.
    No idea how the thresholds have changed between the 2nd and 3rd gen Prius though. I'm also willing to gather additional data.
    Another thing: I have the 2nd Gen 2008 Prius BSU from the junkyard pack, if you don't have one, do you want me to mail it to you? It seems my Youtube comment got deleted from your recent RMA Youtube video. I assume these parts aren't a match between Gen 2 and 3? I know you are working on the Gen 3 first, but if having a 2nd Gen Prius BSU earlier helps, I'm happy to send it over.
  9. mudder
    305
    413
    Chattanooga, TN
    Howdy and welcome, fellow Insight tinkerer! Thanks for the real-world drive data from your tired Gen2 pack.
    I've got a Gen2 BSU already, but thanks for the offer to ship me one.
  10. mudder
    305
    413
    Chattanooga, TN
    Here's what the LiBSU hardware looks like:
    #130 mudder, Jun 26, 2026
    howardc64, jungle and Brian1954 like this.
  11. darknd666
    darknd666 Junior Member
    176
    24
    Jacksonville, NC
    Youre teasing us with excitement now lol. I cant wait for the finished product.
    mudder likes this.
  12. ChapmanF
    19,025
    Battery porn? What will PriusChat sink to next?
    darknd666 likes this.
  13. Corvairius
    Corvairius New Member
    Marquette, MI
    If you want beta testers sign me up, I'll buy several kits when they're available. Do you plan on doing complete packs or offering the boards alone for people that want to run larger cells?
    jungle likes this.
  14. mudder
    305
    413
    Chattanooga, TN
    You're already on the list. We're doing an internal fleet test for the next TBD² months. After that we'll open a private beta period for people like yourself.
    ²I have no concrete timeline. I'm retired and don't have an ETA... I work on this project as I make time to do so. Hopefully there are still Prii on the road in need of batteries by the time I finish.
    Initially LiBSU is only sold as a complete pack. This decision is based on how much additional work was required to support the "bring your own battery" customers on my similar G1 Honda Insight product. I suspect I might eventually offer a 10.4 kWh variant, just like I did with my Honda project.
    There are some technical limitations to solve in firmware before larger packs will behave well. I've been testing with a 10.4 kWh pack for the past six months, so it does work... but the OEM SoC gauge isn't accurate because the car doesn't understand it has a much larger pack. Unfortunately, the BSU (what this product replaces) doesn't estimate SoC; the main hybrid computer does.
    So we'll have to fool it some other way to make the SoC gauge accurate. My leading theory right now is that I can spoof higher regen and lower assist currents to trick the main hybrid computer into thinking that the SoC hasn't decreased as much (or even that it has increased). This is a "future me" problem.
    Don't want to give away all the details before the product is ready to ship.
    That single picture provides a TON of insight into the general architecture, without giving away the details. I don't typically compete in fields where I have competitors. Typically I pick a niche that nobody else has explored/commercialized yet. However, in this case I'm late to a very large party, so for once I'm hiding some of the details for now. I have zero doubts that my competitors will get ahold of my prototype units, but that at least takes more work than me simply spilling the beans for all to see.
    Related: InsightCentral's benevolent overlords have a hyperactive "objectionable content" filter, which flags all kinds of harmless photos. Coolant hoses, skin-colored seats, air intakes... all hidden from our sensitive eyes.
    Based on what I've seen to date, I doubt there's a bottom on how low this forum will go ;).
    #134 mudder, Jun 26, 2026
    rjparker and Corvairius like this.
  15. Corvairius
    Marquette, MI
    I would very much like to purchase some bare boards with the agreement that I expect no support if you'd be willing, as I have a few non standard Prius based drivetrain swaps that would massively benefit from larger packs.
  16. A.J
    A.J Junior Member
    60
    Worldwide
    When this becomes a product, i believe it will surely sell because we don't have a real alternative battery out there till date like what LiBSU is bringing on board.
  17. Dayanul
    Dayanul Junior Member
    2020 Prius
    Limited AWD-e
    Regarding the SOC fooling, I had a few questions regarding that. From what I understand and based on the repair manuals, the OEM Battery ECU senses the voltage of the modules, monitors the current, and the temperature as well as the battery fan. Then it sends relevant data via the BTH+ and BTH- differential signal wires at what seems to be 9600 baud based on the oscilloscope graphs. Interestingly what was puzzling me, when I looked at the DTC sections it says that the HV ECU also calculates the SOC based on the current data the OEM BSU. Meanwhile, the OEM BSU also determines the SOC. Like you mentioned, there would obviously be a problem if the OEM BSU reports a different SOC say if we were using a 64s 50ah lfp battery pack because obviously it would take a lot longer to discharge a big battery pack. What I thought was that the custom BSU would be programmed to map the actual battery pack SOC as follows: 10% real SOC -> 40% HV ECU SOC and 90% real SOC -> 80% HV ECU SOC or something like that. Its honestly no big deal if the SOC guage in the center display isnt accurate (in fact it isnt even accurate to begin with because of toyota's conservative engineering). What is important though is that whether or not the HV ECU throws any codes if the aftermarket BSU reports a different SOC via the BTH lines. That is the main question. Let me know if you figured that part out.
  18. Dayanul
    2020 Prius
    Limited AWD-e
    Isn't there supposed to be SOC data as well?
  19. mudder
    305
    413
    Chattanooga, TN
    FYI:
    Everything I write in this post is in regard to the Gen3 architecture (which my LiBSU product is designed for).
    Based on my analysis of the BTH data stream and in-vehicle behavior with LiBSU, I'm confident the BSU does not calculate SoC. Instead, the BSU passes all the parameters used to calculate SoC (voltage, current, temperature) to the main hybrid computer, which then uses said data to calculate SoC.
    I agree (preemptively) that this is an odd design decision... the BSU ends up having to send a TON more information to the main hybrid computer, versus just the SoC and safety flags if the BSU were to calculate SoC directly (as is done in Honda's hybrid architecture).
    Note that my LiBSU firmware isn't sending any SoC information to the main computer, and yet the car is still calculating SoC (presumably on the main hybrid computer). I spent a couple months decoding the entire BTH bus last year, hence my confidence that the BSU doesn't calculate SoC. At this point I know what every single byte in the data stream does. Nothing is unaccounted for.
    As always, anyone can disprove my claim by showing me where I'm wrong...
    ...I'm always open to factual disagreement.
    If "HV ECU" is referring to the BSU, then I propose this statement in the service manual is incorrect, per se... whether or not the BSU or main hybrid computer calculates SoC isn't important to nearly everyone reading the service manual. The only people who need to know this distinction are those crazy enough to redesign the BSU entirely.
    Another option is that "HV ECU" is the main hybrid computer, which is almost certainly calculating SoC (by process of elimination, given that I'm certain the BSU does NOT).
    This is a moot point for the Prius, due to the BSU not reporting SoC...
    ...but as an academic hypothetical, I'm not certain it would make sense for both the BSU and the main hybrid computer to calculate SoC from the same dataset (voltage taps, current, temperature are all gathered by BSU).
    Honda's equivalent to the BSU (the 'BCM') does calculate SoC, and Honda's main hybrid computer (the 'MCM') blindly trusts it. This is advantageous for larger packs, because a replacement lithium computer (that I call LiBCM) can report actual SoC without issue, even when the pack stores 15x more energy.
    I, too, thought I'd remap the SoC as needed to maximize energy cycling through the pack.
    However, SoC isn't a lever we can modify, because the BSU doesn't calculate it.
    I agree, although it's a "nice to have" feature.
    For reference, the OEM SoC gauge doesn't work properly with my LiBCM product on USA G1 Honda Insights. Oddly, it does work correctly on JDM Insights. I still haven't figured out why this is the case, so for now LiBCM displays actual SoC via an aftermarket LCD display (included with every kit).
    Since the BSU doesn't send SoC data, it is impossible to add said data to an aftermarket BSU replacement.
    As I mentioned previously, since SoC is calculated from data that is only gathered from one source (the BSU), there's minimal safety margin gained by redundantly processing the same data on two computers, and then comparing.
    Aside: Parallel redundancy like this is an important safety concept in SIL-3 & SIL-4 products. However, Toyota's hybrid architecture is in the lower ASIL-C safety class, which is roughly equivalent to SIL-2, which is why Toyota doesn't have redundant sensors and computers for the same operation. Hybrid batteries aren't nuclear power plants.
    #139 mudder, Jul 4, 2026
  20. ChapmanF
    19,025
    This seems to be a gen 3 decision to simplify the BSU. In gen 1 and gen 2, it was a full-fledged "Battery ECU" that had its own network address and PIDs and trouble codes. Gen 3 turned it into more of an appendage of the HV ("power management control") ECU under the dash, by a dedicated point-to-point comm link.
