License Plate light bulb Replacement - 2006 Prius
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by NorthsidePaul, Oct 11, 2014.
  1. NorthsidePaul
    NorthsidePaul New Member
    McKinney
    How do you replace the license
  2. JC91006
    16,496
    8,406
    You have to remove the inner hatch cover to get to the bulbs. Pull the cover off forcefully,rip it right off. You cannot be gentle with it.
    This may end up hurting your fingers because the cover is held tightly by 11 blue tabs
  3. NorthsidePaul
    McKinney
    Thanks! Ok, I'll take my lumps. But, important, how do you put the hatchback panel back on again properly? What are the chances of breaking the blue tabs or the panel?
  4. JC91006
    16,496
    8,406
    It's pretty hard to break the cover, it's pretty flexible. There is a very small chance to break the tabs, you would need to pry off the ones that are stuck to the car hatch and put them back on the cover. There should be 11 total.
    I've taken these apart numerous times on my 3 Gen2 cars, never broken one yet.
    Woodstock74 likes this.
