Lifetime Average MPG
Discussion in 'Prime Main Forum (2017-2022)' started by ShellyC, Nov 23, 2018.
  1. ShellyC
    ShellyC Junior Member
    MEdford, OR 97504
    2018 Prius Prime
    I'm confused again. My lifetime average MPG went down this morning while I was on electric power. It was not significant but seemed strange since I wasn't using any gas. I turned the car off and back on again which seemed to fix it (the MPG starting climbing again). I'm just curious what might have caused what seems to be a strange anomaly? Any ideas?
  2. Mendel Leisk
    42,365
    When I search a pdf of the US 2012 Prius Plug-In Owner's Manual, I can't find the word "lifetime". Is this one of the trip meters?
    52,880
    idk what lifetime mpg is either, but pip does have two screens for ev/hv ratio along with the two trip meters.
    i use one of the screens for lifetime and one for the tank of gas.i use one of the trip meters for the tank of gas and the other for each trip.
    no way a trip meter could go down on ev, that i have seen. there are some folks who haven't been aware that the engine is on (my wife can never tell) and shutting down and restarting puts you back in ev.
  4. Salamander_King
    Salamander_King Senior Member
    11,024
    8,980
    New England
    "Lifetime average MPG" Maybe this?
    EDIT: Whoops. OP has PIP not PRIME. Then IDK.
  5. bisco
    52,880
    unfortunately, o/p is in the wrong forum. or, has a prime and we don't know?
  6. heiwa
    heiwa Active Member
    223
    216
    Central Valley, CA
    In the OP' another original thread "Charge capacity", OP talks about EV range of 27-28. It must be Prime.
    Did you reset ODO average MPG by holding TRIP button by mistake?
  7. ShellyC
    MEdford, OR 97504
    2018 Prius Prime
    I'm not sure how that car got applied to my profile. I will correct. I have a 2018 Prime. Salamander King's picture is what I'm talking about. I have not reset this meter so it shows the MPG for the "lifetime" of the car. At least that is my assumption. It's called ODO average MPG? It was going down and I was in EV mode with a full charge and in traffic/motion. I was just curious since that seemed odd.
  8. Salamander_King
    11,024
    8,980
    New England
    How many miles on Odometer? I don't know how often they adjust this mpg, but maybe you were driving HV on previous few days and that got calculated into the mpg for the a while you were driving on EV? Or it could be just some kind of computer bug. My understanding is that your 2018 PRIME have 999.9 mpg as limit, correct? So it it much more sensitive than my 2017 PRIME which has 199.9 as limit. In any case I have never watched ODO mileage while driving my car. I always have it on Trip B which is my in between gas mileage.
    #8 Salamander_King, Nov 27, 2018
  9. padroo
    padroo Senior Member
    2,763
    2,253
    Have you been mistreating your Prius?
    Maybe it is punishing you.
    I don't have a serious answer.
  10. ShellyC
    MEdford, OR 97504
    2018 Prius Prime
    I have 2400 miles on it. No HV driving yesterday but this happened again this morning. I left a message with the service folks at the dealership to see if they can explain it. Yes, the limit appears to be 999.9 mpg. My overall average is 131.8 mpg (it was 132 when I got in it this morning).
  11. Salamander_King
    11,024
    8,980
    New England
    Good luck with that. Most of dealer tech probably have no idea why PRIME displays such high mpg to begin with. lol
    So, from ODO 131.8 mpg without doing any HV run, you get 132 mpg on display? But after running while, it comes back down to 131.8 or lower if you have extended EV run? If that is the case, maybe computer is simply rounding up the number until it received more driving data, IDK. In any case, the difference seems to be very small. If I were you, wouldn't worry about it too much. I will check my ODO mpg next time I drive on extended EV. For now, the cold temp has gotten hold of our region, I have been driving HV every morning when I first get in the car.
