Lifetime EV Driving Ratio
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by vinhboy, Sep 4, 2012.
  1. vinhboy
    vinhboy Junior Member
    25
    Davis, CA
    I took my car in to a shop and for some reason they reseted my trip meter.
    I am curious if anyone knows if the PiP has a Lifetime EV Driving Ratio.
    To me, it is the only useful display screen. It would really be a downer if it is only available on a per-trip basis.
  2. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    Here's my Lifetime since April 23, 2012
    EV Driving Ratio
    EV 61%
    HV 39%
    228KWH TOTAL SO FAR
    12 GALLONS OF GAS SO FAR
    Fuel saved by charging 19.1 GALLONS
    EV MILES SO FAR 929
    HV MILES SO FAR 588
    TOTAL MILES SO FAR 1519 AS OF September 4, 2012
    Still have a full tank of gas
    Average MPG as of this date: 1519 miles/12 gallons=126.58 MPG
    vinhboy likes this.
    52,875
    it would be nice if there were some permanent records that could not be erased.
  4. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    Hasn't been erased so far..........I text the latest to myself....then when I get back into my 14th floor apt. I copy the info down, just in case it's not lifetime.....How long does the display record for?
  5. bisco
    52,875
    good question, but writing it down is a great idea.
  6. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    :D
  7. ultraturtle
    108
    81
    Peachtree City, GA
    It does as long as power from the accesory (12V) battery is not disconnected. Trip meter, clock, calendar, EV/HV driving ratio, and probably a few other settings reset when the 12V battery gets disconnected, which is probably what the shop did.
    Some shops plug in a 9v battery to the cigarette lighter to maintain settings such as these when removing power from the battery, but that approach has never worked on previous cars, so I did not bother when I disconnected the battery for some recent tinkering I did on my sound system. You will probably come across recommendations to attach a 12V battery charger to the battery leads to maintain such settings should you need to detach the battery to work on something in the 12v system. I don't have to explain why that is a really bad idea.
  8. Chris11
    Chris11 Member
    220
    Washington
    Did you check both #1 screen and #2 screen under the EV Driving Ratio? Perhaps they just reset the one you had it on at the time?
  9. vinhboy
    25
    Davis, CA
    Yes. Checked both. Both reseted.
    I guess the consensus of the thread is that there is no lifetime storage of this information.
    That really blows.
    I look forward to the day someone root the PiP so we can write better apps for it. ;)
  10. ryogajyc
    ryogajyc Active Member
    985
    165
    Reseda, CA
    I wished for an iPad dock before, but someone mentioned MirrorLink which could work for iOS and Android which would require no rooting either. Anyhow, now I wish for MirrorLink.
    Toyota MirrorLink | PriusChat
  11. rogerv
    rogerv Senior Member
    1,639
    317
    Simi Valley, California
    I've mentioned this in another thread, but on my daughter's '11 hatchback, the 'trip b' odometer she was using for lifetime data reset itself at exactly 10K miles. She had her service done a few miles early, so it wasn't reset by the dealer. If this has been corrected for the PiP, we need to hear from someone who has already racked up 10K miles. Otherwise, keeping independant records might be a good idea.
  12. ukr2
    ukr2 Senior Member
    1,020
    278
    31
    Victor, NY
    For the 5000 checkup, they needed to reset Trip#1 to reset the Maintenance Reminder.
    I use Trip#1 and EV#1 for test intervals and I use Trip#2 and EV#2 for Fillup data, resetting them after each Fillup.
    There are No Lifetime data values that can't be reset on purpose or by mistake, that I know of.
  13. bisco
    52,875
    i bet it's lurking in the black box.
  14. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    9999 is and should continue to be the max.
    The reason is simple.... margin-of-error becomes greater than the variance after that many miles.
    That's recommended regardless, since the display value is just an estimate. Measuring at the pump & plug is always better.
  15. John H
    John H Senior Member
    2,208
    558
  16. drinnovation
    drinnovation EREV for EVER!
    2,027
    586
    65
    CO
    That would require the PiP to have some type of remote reporting capabilitiy, which it does not.
    However there is self-reporting data discussed in this thread, see the shared spreadsheet
    PIP & MPG Spreadsheet | PriusChat
    And of course Fuelly which generall works for Plug-in-Prius (but not so good for volts.. since it cannot handle/report more than 200mpg).
  17. John H
    2,208
    558
    What does the "entune" app talk to? Could a smart phone app, or entune, bridge the data from the PiP to a cloud app?
    I like PriusKitty's method of sending a text message as well. Maybe take a google voice number and then write a script to read txt messages from GV and put them into the MPG spreadsheet. The sender's phone number could be mapped to their userid so that everyone could txt to the same gv number. The script could ack the incoming message with some lifetime stats for EV%, MPG, etc ... and an empty template for the next incoming message.
  18. drinnovation
    2,027
    586
    65
    CO
    For those with entune it could be automated.. basically reverse engineering the phone APP and making the same call to the cars. That is what Mike did to make volt stats. But all volts have onstar for at least 3 years.. what fraction of PiP owners have Entune?
    If people want to do the txt message route I could help with that. I've done a bit of txt message software hacking, this semester I'm starting to use it in my classroom for rapid feedback from students, also done it for "people choice" awards for various events.
    If people here are interested I can setup a number, define a standard formatted message and then do automated processing and insert the resulting status into a webpage or script.
    I could do the reply message with stats as well, though the outgoing text messages cost me money ;-), so I'd prefer to just push them into a webpage that people could review. (My time is easy to "give", and I pay for the number anyhow, but paying for the outgoing for this would probably violate some state law). I do like the idea of an empty template, so maybe when people first signup I could have it text them once (so they know the number and have the template).
    What data should it collect.. Same as in the PC spreadsheet? (Or should it be adapted?)
    If enough people say this is a good idea (by replying or "liking" this post) then I'll hack something together..
  19. John H
    2,208
    558
    maybe twitter instead of txt messages ?
  20. drinnovation
    2,027
    586
    65
    CO
    I've not done much tweet processing. Not everyone has twitter on a phone.. (In my class all but 1 had txt phones, only about 60% had smart phones).
