Lifetime MPG
Discussion in 'Gen 3 Prius Main Forum' started by Petemcneil, Mar 28, 2012.
  1. Petemcneil
    Petemcneil New Member
    Rhode Island USA
    I am a new owner of a Prius III. I have been driving for two weeks and have yet to find the cumulative MPG. I presently use Trip A to monitor MPG. I have the basic audio display system with Navigation and solar roof. Any help would be appreciated.
  2. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    You have to use trip a or b to track cumulative MPG, just don't reset it and it shows cumulative.
    I use A to track cumulative and never reset it and B I reset either each day, each trip, whenever I want to etc.
  3. Petemcneil
    Rhode Island USA
    Thanks...seems like Toyota would something a little more sophisticated than the trip calculator. I can see one of my grand kids erasing Trip A within a month
  4. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    If your grand kids are sitting behind the wheel with the car running then you have bigger issues to contend with than an erased mpg indication. If they are old enough to drive then they are old enough to instruct what not to do in your car.
  5. sooperedd
    sooperedd Junior Member
    48
    Colorado
    I use Trip A for each fill-up and just let Trip B alone so it will calculate lifetime.
  6. d2mini
    d2mini Active Member
    519
    106
    Houston
    That is kind of lame. Most modern cars with an OBC track lifetime mileage. Or I should say mileage since the last time the battery was disconnected.
  7. fuzzy1
    10,707
    Mine was reset by a clumsy technician at the second oil change, back when it had a shorter change interval. And for some reason I mistakenly reset the wrong trip meter about once per year. But since I use it for tank mpg, not lifetime mpg, less information was lost. Results are recorded in a notebook at every refill, then lifetime mpg and other metrics are computed on a spreadsheet.
  8. jdenenberg
    jdenenberg EE Professor
    3,961
    1,957
    Trumbull, CT
    2020 Prius
    LE AWD-e
    I just maintain an Excel spreadsheet of all my gasoline purchases that tells me that my 2004 Gen2 Prius at 220,000 miles has averaged 45.8 MPG over its life of over 8 years.
    JeffD
  9. kstephens
    kstephens New Member
    28
    Kentucky
    Same here.
  10. yueq
    yueq Junior Member
    MD
    Is there a maximum limit on the trip meter?
  11. Slugdoc
    Slugdoc New Member
    50
    Bronx, NY
    fuelly.com
  12. Mendel Leisk
    42,345
    If you can keep track of all the gas you've bought since purchasing the car, and the odometer reading at purchase, you've got what you need. Unless the car has some sort of flash memory (not a bad idea...) it will lose overall mileage any time the battery is disconnected.
    And fwiw, Toyota's track record for accurate mpg is not so good. This is apparently rectified on the Prius Plug-In and maybe on Prius C?
  13. Sabby
    Sabby Active Member
    295
    127
    SoCal
    I use the attached spreadsheet. Perhaps it can help someone else out.
    When you fill up fill in columns C,D,E and F. At the end of
    each month if you press the "Refresh Pivot" button (around cell K22) it will keep a running summary by year and by month. :focus:
  14. p00kienrayray
    p00kienrayray Active Member
    720
    135
    Long Beach, CA
    I use Trip A for cumulative (never resetting), Trip B reset after every fill up. I don't care about calculating per trip b/c the HIS display calculates and tells me what the trip mpg is after I turn off the ignition.
    Also, I use fuelly as well, as you can see below.
  15. RRxing
    RRxing Senior Member
    2,563
    1,842
    NEPA
    I use a spreadsheet as well. Easy enough to compare actual MPG to displayed. I use Trip A for my daily jaunts to and from work and Trip B for my tank to tank numbers.
    Actual average MPG of 47.66 from July 2009 with 37,810 miles.
  16. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    If you set up an account and log your fillup at Fuelly | Share and Compare Your MPG can see your actuall mpg and whole lot more.
  17. daevumshlebee
    daevumshlebee New Member
    glad i found this thread. kinda disappointed that the gen iii prius does not keep track of overall/lifetime mpg....the older models did (although i suppose it is arguable that the stat was not very accurate anyway).
    i've already made the mistake of resetting my trip a and trip b...maybe i can reset one on Jan 1 and keep track of my yearly mpg lol
  18. Sporin
    Sporin Prius Noob
    576
    293
    Vermont, USA
    I reset the trip (usually both) at each fillup and use Fuelly to track my lifetime.
    fwiw, I've found the onboard to be about 5% optimistic over the 50k miles I've tracked.
    Also, my average now, barely moves, because after so many fillups, you need a bunch of large swings to move the needle, so to speak. Basically, I could stop tracking from now to forever and not expect my average to change more then a few decimal points.
    Cliff's Notes: Lifetime average is sort of meaningless imo.
