Liftgate garnish broken plastic cheap repair
Discussion in 'Gen 2 Prius Main Forum' started by remaker, Aug 28, 2022.
  1. remaker
    remaker Junior Member
    The thin plastic bits plastic holding in the square bolts on the garnish finally broke for me, and I didn't want to spend $80 on a replacement garnish. I was sorely tempted, especially seeing the OEM upgraded ones with the metal bracket replacing the poor plastic design.
    My fix? Tie wraps!
    There is a thin pathway under the plastic mount point perfect for routing a tie wrap. I used the thick ones I had from Harbor Freight, but would choose a thinner one if I had to buy them.
    Here are some photos of my hack. Hope this helps someone. I will update the thread if my fix fails.
    Another likes this.
  2. PriusCamper
    PriusCamper Senior Member
    13,467
    5,435
    Pacific Northwest, USA
    Interesting idea... Didn't think there was enough room for that? I had a friend who doesn't like to spend money and wanted me to glue all the busted pieces together and I used liquid steel epoxy and told her it might not work. But to my surprise after a few months it's still holding strong. Didn't expect that. I might try it again with my own car which has this problem thanks to rear hatch freezing shut at a rest stop last Christmas.
    remaker likes this.
  3. remaker
    Everyone seems to say "epoxy won't work" so I didn't try. Not sure if this fix will fare better, but we'll see!
  4. PriusCamper
    13,467
    5,435
    Yeah... I felt the same way, but when someone is willing to pay you to do it and find out... I did my best to add some reinforcements to strengthen it and if you spend enough time opening the hatch when it's broken, you develop a technique that puts the least amount of force on the weak spots, so maybe that's part of why it's continuing to hold strong?
    remaker likes this.
