Liftgate Handle Screws
Discussion in 'Gen 2 Prius Main Forum' started by Alona Culver, Feb 10, 2019.
  1. Alona Culver
    Alona Culver New Member
    Rochester, NY
    I have a 2007 Prius, the liftgate handle is coming off, the original clasps are not holding it on properly. Does anyone know the size of the screw and bolt that I would need to replace those with? Thanks.
  2. JC91006
    16,672
    8,518
    It's not replacing a screw, it's broken. You need to replace the entire handle.
    Some people have found creative ways to glue/putty/bolt down the handle, but the proper repair is to replace it.
    Skibob likes this.
  3. dolj
    dolj Senior Member
    8,209
    4,180
    Wellington, New Zealand
    BTW, it is not a handle, it is a decorative strip. When you use it as a handle, it breaks. The liftgate should be lifted by pressing up on the switch, and then if necessary grab the bottom edge of the liftgate, as it comes up, and lift from there.
  4. Alona Culver
    Rochester, NY
    It came broken. We purchased the vehicle used. I don't pull on the handle if I can't help it. My hand always tries to pull up on the bottom of the hatchback, not the handle.
  5. gptoyz
    gptoyz Junior Member
    79
    16
    los altos
    that trim piece is done, you can try all the epoxy in the world
    it's easier and faster just to buy a trim piece of the same color. Just remember that there are both screws and clips, the screws gotta come off then the trim piece can be removed by pulling away
  6. Alona Culver
    Rochester, NY
    We took it to the dealer had it replaced. Thx.
