Liftgate maintenance... odd question
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by tvspaulmoore, Jan 27, 2014.
  1. tvspaulmoore
    tvspaulmoore Junior Member
    37
    Dunedin, FL
    Hi there
    I'm sure I should know this but can't seem to find the answer- can I lubricate the liftgate to stop it squeaking/creaking when opened?
    Thanks
  2. jdenenberg
    jdenenberg EE Professor
    3,957
    1,955
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Spray some WD40 on the hinges and the ball joint ends of each pneumatic damper. This should be done every 6 months (don't forget the door hinges as well).
    JeffD
  3. tvspaulmoore
    37
    Dunedin, FL
    Thanks- I was worried that using WD40 would 'damage' it somehow- but that was obviously me worrying over nothing!
  4. Indy John
    Indy John Member
    75
    33
    Indianapolis
    My '04 developed a squeak and rattle in the rear that was driving me crazy. I finally isolated the problem to the spoiler. After removing the plastic panel, I was able to access the threaded fasteners and tighten them up - fixed the problem.
  5. PriusGuy32
    1,417
    514
    Harrison Township, Michigan
    I dont have squeaks, creaks or creeps in my trunk area.... :D
    But I do have bad liftgate shocks. In the cold, the liftgate needs to be pushed up with significant force and then it usually falls and bangs me in the head :mad:
  6. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    I've been told to NOT use WD40 in situations as described because it being petroleum based it will actually attract dirt. So it was recommended to use a silicone or synthetic lubricant.
    I know in the bicycling world there are those that WON'T use WD40 on their bike chains for that reason.
    elementnomore likes this.
  7. PriusGuy32
    1,417
    514
  8. Mendel Leisk
    42,075
    I used a little silicon spray, very sparingly on door and hatch hinges, about year after purchase. Nothing since. For shock tubes on the hatch, I'd be very catious, just keep the shiny bit clean, no spray or oil.
  9. The Electric Me
    9,083
    5,801
  10. jdenenberg
    3,957
    1,955
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Mendel,
    The little ball joints at each end of the "shock tubes" tend to corrode, so a light spray there can help and don't forget the hatch hinges.
    JeffD
    PriusGuy32 likes this.
  11. PriusGuy32
    1,417
    514
    Exactly...thats why I posted it :D WD40 (The Brand) makes a silicone spray. Its not the same as their traditional spray lubricant/penetrant. And it works great!
  12. The Electric Me
    9,083
    5,801
    Yes, but up to that point in the thread only "regular" WD40 had been mentioned.
    Fine as long as everyone is comparing Apples to Apples.
    I don't care what the Brand Name is, the point is the same. Regular WD40 is petroleum based. There are various and numerous Silicone sprays available....including one made and branded by WD40.
  13. tanglefoot
    tanglefoot Whee!
    625
    188
    Colorado
    I put a little grease on the pneumatic strut shafts from time to time--it really smooths out the operation.
    I've noticed the struts don't provide as much lift in cold weather as well. It might just be due to the gas law--a volume of gas at lower temperature has less pressure.
  14. exstudent
    exstudent Senior Member
    2,214
    905
    Torrance, CA
    Your failing hatch lift supports got me wondering how much they are:
    Amazon: $18.90/ea for StrongArm
    Camelback Toyota: $96.86 (right), $96.61 (left) for Genuine Toyota part.
    Price difference quite large.
    You might be able to find Genuine Toyota lift supports a little bit cheaper at another online Toyota parts department, but Camelback has been pretty good on prices; some things just slightly more, other things slightly less. I like b/c price competitive and they are very close (Arizona).
    SFO likes this.
