liftgate repair
Discussion in 'Gen 2 Prius Main Forum' started by volcano, Feb 10, 2017.
  1. volcano
    volcano Junior Member
    i have at 2008 prius that has a broken liftgate. i have used the hatch alot durning college and the plastic is brittle and is broken. i need to remove the liftgate so i can use epoxy for repairs, but i am not certian on how the liftgate comes out.
  2. JC91006
    16,923
    8,634
    The hatch handle right? That's the only non metal part
  3. volcano
    yes, there is some plastic parts that are broken by the holding posts.
  4. JC91006
    16,923
    8,634
    You're better off replacing the broken handle with a used part on eBay. Epoxy won't last long. Remember that is not really a pull handle, you should pull up on the metal part of the tail gate.
    To remove that handle, remove the inner plastic trim on the inside on the tail gate section. Once that is removed, you'll see 4 bolts/nuts that hold the handle in place. Remove that and replace with a new part
    jerrymildred likes this.
  5. Akramahmad1
    Akramahmad1 New Member
    Check this out:
  6. mr_guy_mann
    mr_guy_mann Senior Member
    4,109
    2,011
    NJ-USA
    Everyone uses the plastic part as a handle because it is handle shaped and happens to be where you hand is already applying pressure on the release switch, and in the same direction no less. I doubt that Toyota designed the tailgate so that the owner was supposed to pull up on the bottom edge of the hatch.
    My guess is that the tailgate lift pistons are supposed to push the hatch open when you press the release switch. They produce less force as they get older and need a "boost" to start opening so people pull on the old- brittle - plastic "looks like a handle but isn't" until it breaks.
