Lifting a Prius c?
Discussion in 'Prius c Accessories and Modifications' started by Leadfoot J. McCoalroller, Jul 9, 2018.
  1. NyQuil
    NyQuil Junior Member
    30
    2016 Prius c
    Oh, I just saw that the old post mentioned something about a trailer.
    I've hauled at most 1000lbs and got good milage on the highway (mid 30's I think?). Keep your acceleration and deceleration long and slow and you'll be fine
  2. topshot
    topshot Member
    154
    58
    Midwest
    2015 Prius c
    That's pretty surprising from what others with larger tires have written. Those tires should be significantly heavier than OEM.
    Anyway, did you lift just for snow or to travel rough roads? I was recently at a trailhead that several full-size Prii had attained (in presumably dry weather), but I wouldn't take my baby there - shorter wheelbase and no underside battery cable protection make rocky roads a no-go for her. Maybe when I have another 100K on her. ;)
  3. NyQuil
    30
    2016 Prius c
    On paper it's heavier and should have an impact (actually was a bit cheaper than oem tires xD) but I see this arm chair speculation a lot and really wonder just how much of is just speculation. Traffic, include be, and just how people drive have such a way bigger impact that I feel that things like tires, roof racks, lift kits, is just mole hills. Hills to be sure...but mole hills.
    Lifted for clearance and look. The larger tires required the lift too (driving without them has been tedious)
  4. champion510
    champion510 Junior Member
    23
    Did you already post the pics of your upgrade?
    I'd love to see how your ride looks now.
  5. NyQuil
    30
    2016 Prius c
    Im not the best at taking these.
    This is 30mm on the front and back. I actually got in a 40mm for the back as I would like a bit more when hauling a lot but I haven't installed them yet
    Danny13pruisc3 likes this.
  6. topshot
    topshot Member
    154
    58
    Midwest
    2015 Prius c
    Where was this measurement taken (I assume full tank of gas but empty of any passengers or cargo)?
  7. NyQuil
    30
    2016 Prius c
    Bottom of the frame under the driver door.
    Yes but I couldn't tell ya if it had a full tank or not.
  8. Danny13pruisc3
    175
    28
    maryland
    I would have gotten the same width but taller.. I would think the taller wheels would get better MPG..
    but the friction from the wider tire might offset it..
    i'm thinking lower to the ground lets lesss wind into the undercarriage to lower the wind resistance..
    I'd like taller.. but hmm?
  9. topshot
    topshot Member
    154
    58
    Midwest
    2015 Prius c
  10. Adventurer2112
    Adventurer2112 Junior Member
    55
    Urbana
    2014 Prius c
    Hi All,
    Thanks, I am interested in a lift kit, for the winter snow.
    Jack
  11. Adventurer2112
    55
    Urbana
    2014 Prius c
    Hi All,
    Bought the Prius off road lift kit for my 2014 C.
    Now to find a willing competent installer.
    Jack
  12. farmecologist
    farmecologist Senior Member
    1,960
    1,801
    Southern MN
    Cool! Show us a pic or two once you get it installed! (y)
  13. topshot
    topshot Member
    154
    58
    Midwest
    2015 Prius c
    I wouldn't have considered Urbana to have enough regular snow just for this. I'm about an hour south and would do it mostly to reduce hitting the skirt on high curbs/parking stops (and getting to some trailheads out west). :)
    Would be nice to see before/after pics.
  14. Adventurer2112
    55
    Urbana
    2014 Prius c
    Hi All,
    Yes for more clearance for countryside deliveries.
    I will take pictures. jack
    Pri3C and farmecologist like this.
  15. Pri3C
    Pri3C Active Member
    183
    131
    Midwest
    2014 Prius c
    Waiting for those pictures! :)
  16. AZPriusC
    AZPriusC New Member
    Arizona
    First-off, that looks awesome!
    How extensive was the body modding to remedy the rub? I’m getting my Prius C lifted on Monday, and I’d like to go with the same tire size to maximize the ground clearance and ride height.
  17. NyQuil
    30
    2016 Prius c
    Might be a tad late here but outer body required none, did have to take a large hammer to the wheel well and cut some of the wheel well plastics
  18. UpNrth
    UpNrth New Member
    United States
    2015 Prius c
    Just checking about pictures? Also if you changed wheel/tire size at all? Thanks, I’m grinding snow underneath my 2015 C..
  19. Adventurer2112
    55
    Urbana
    2014 Prius c
    Hi
    Haven’t found a trustworthy installer yet.
    Jack
    UpNrth likes this.
  20. AzusaPrius
    AzusaPrius Senior Member
    2,257
    942
    For anyone that would like to save 5% on a lift kit.
    Use code "azusa" at priusoffroad.com
