Light-bar upgrade for LE and SE
Discussion in 'Gen 5 Prius Main Forum' started by Gokhan, Sep 24, 2023.
  1. Gokhan
    Gokhan Senior Member
    6,715
    2,672
    Paramount CA
    I drove behind a gray Gen 5 LE for a long time last night.
    Conclusion: It looks like the tailight bulb burned out. It is an awful, awful design by Toyota. Why would you put a taillight lens without a bulb inside? It has no reflectors; so, it makes no sense whatsoever.
    Eventually, I passed it, and the headlight design is equally awful. There are no yellow marker lights or accent lights visible from the front and the headlights look tiny, barely visible to other drivers. In contrast, the quad LED headlamps on my 2021 Prius Prime Limited are simply beautiful, and I have yellow marker lights visible from the front, accent LED lights, as well as driving/fog lamps. I have so many lights that when I am behind someone, it scares them, which should be the way it is for best visibility.
    Why spend so much effort in designing an elegant shell but completely ruin the taillight and headlight design?
    soft_r likes this.
  2. Zeromus
    Zeromus Active Member
    553
    309
    Ottawa Canada
    2024 Prius Prime
    SE
    To try and get us to buy upper trims for another 5-6k ;D
    FWIW at least while driving the headlamps feel plenty bright and the turn signals are very visible. But yeah upper trims do have prettier versions.
    Maybe far into the future if/when the lamps get gross and burn out they get swapped XD
    Lantaral and Gokhan like this.
  3. swisshurb
    swisshurb Junior Member
    CA
    2023 Prius Prime
    SE
    anybody has any progress around here ? :D
  4. Gokhan
    6,715
    2,672
    Paramount CA
  5. EnriqueDFA
    EnriqueDFA Junior Member
    25
    Mexico
    2023 Prius
    Will probably try next year. It is quite expensive, specially the harness to the rear door, I'll probably use connection to the side tail lights like the Japanese blog post lol
  6. Avade
    Avade Junior Member
    california
    2024 Prius
    LE AWD-e
    hello!...it's been a year.... anybody tried them yet? a youtube tutorial will be a banger
  7. EnriqueDFA
    25
    Mexico
    2023 Prius
    Not yet, I barely got the car 3 months ago lol I've decided to pay out the car first before modding it, so it'll take more time. So far the japanese blog post has been the best guide i've found.
    Avade likes this.
  8. Gokhan
    6,715
    2,672
    Paramount CA
    Actually, having seen a lot more Gen 5s on the road, I think the LE/SE taillights are not that bad. Light bars have become too common, and they are starting to appear nauseating. So, I think the LE/SE taillights look good—albeit perhaps with the caveat of being a little too small for the safety aspect.
    Avade and Alessandro_Ibi like this.
  9. Gokhan
    6,715
    2,672
    Paramount CA
    I also still get highly impressed when I see Gen 4 Prius Prime taillights on the road at night. They are one of the best taillights ever when viewed at night with the way they light and the way the center high-mount stop light lights (like a quasi light bar).
  10. scotched
    scotched Member
    81
    112
    Encino, CA
    2023 Prius
    At night, I don't like the design of the uni-tail light on the Gen 5 for two reasons.
    1. It isn't straight. It has the shape of a bow-tie rather than a line. Instead of minimal is looks "busy".
    2. It isn't WIDE. The rear lights do not span the width of the car due to the way the rear fenders bulge. It make it look like there is less car on the road.
  11. EnriqueDFA
    25
    Mexico
    2023 Prius
    Well, after a long time of planning, I might do this, I have most of the parts identified but I'm missing one, and it's the harness that goes from the fuse box (I think) to this one 81935-47090 (the one that powers up the middle brake light and the two lights for the bar) since the one on my prius doesn't have constant power for the two lightbulbs on the bar. Any one has a clue on the part number for that?
  12. Perfectpacman
    Perfectpacman Junior Member
    85
    24
    United Kingdom
    2024 Prius
    ----UK----
    Absolutely. Of course they're visible, but by far my most annoying thing about the car. Completely ridiculous decision by Toyota.
    Gokhan likes this.
  13. EnriqueDFA
    25
    Mexico
    2023 Prius
    Just wanted to update this that I bought the parts, installed them and it works!
    In summary, I spent around 280 USD in parts and 50 on hiring a dude to replace them since I'm a clumsy lol
    mingc, VelvetFoot and Gokhan like this.
  14. Gokhan
    6,715
    2,672
    Paramount CA
    Could you list the parts?
  15. EnriqueDFA
    25
    Mexico
    2023 Prius
    81581-47080: For the rear body (red line is different with mirrors and stuff plus 2 holes to insert the leds)
    81935-47090: Harness to replace the existing one that only feeds stop lamp, this has 2 extra connectors for the leds
    81965-46010: The red leds, you need 2 of these
    75431-47050: The Toyota emblem for the rear body, trying to remove the existing one will pretty much ruin it.
    I ordered all of them from japan, for some reason I was not asked to pay import taxes lol so yay for me.
    There's 1 issue, the conector (rear door harness) that feeds the new harness has the green power cable, but isn't powered, according to my investigation it seems disconnected on the next level; the roof harness, but there are like 10 different variants and you have to take the inside roof to replace that, which is not only riskier but expensive as hell, so... I ended up using the left's taillight power (green cable) using a new cable inside the body all the way to the rear door to power up the new harness. Pretty much that this japanese dude did.
    Gokhan likes this.
  16. Gokhan
    6,715
    2,672
    Paramount CA
    It looks like the parts at Amayama are much cheaper than at Toyota USA.
    #76 Gokhan, Apr 27, 2026
  17. EnriqueDFA
    25
    Mexico
    2023 Prius
    I ordered from Impex Japan, 1 month from order to delivery.
    Gokhan likes this.
  18. Hammersmith
    Hammersmith Senior Member
    2,494
    2,552
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    So about $225 plus shipping? Can I ask about how much shipping was for you?
    I've ordered from Impex a few times. Reasonably good experience as long as you understand you're not going to get your stuff quick. Got burned once on shipping on a large item. I knew it was going to be bad, but it was way worse than I expected. I'm a little more careful now and make sure the stuff I buy from them isn't too big.
    Gokhan likes this.
  19. EnriqueDFA
    25
    Mexico
    2023 Prius
    Close, 75 shipping
    I took my chances and used EMS which translates to MEXPOST here, which is infamous for their long delivery time plus a few missing packages every now and then haha
    There were 2 details:
    1. I used approximate sizes and weight on Impex, but i got at email a 2am saying I missed a 1050 extra yen because the weight increased by a 400 grams or so
    2. The package went through customs almost instantly, I have no idea why it wasn't flagged but I saved around 90 USD in taxes haha
  20. Hammersmith
    2,494
    2,552
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Looks like prices have gone up a bit since you ordered. My Impex cart says Y35,570. So it was good you ordered when you did.
    Even looking at the best case, that parts list would have come to about $425 if ordered from a US Toyota dealership during the best sales. So around $300 from Impex was a good deal.
    Gokhan and EnriqueDFA like this.
