Light Grinding Sound While Accelerating At Low Speeds
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Jon Batchelor, Jul 7, 2026.
  1. Jon Batchelor
    Jon Batchelor Junior Member
    35
    FL
    So water pump was replaced a few months ago, blower motor was replaced a couple of weeks ago (that one was actually almost as easy as expected!), a new set of tires about a month ago ... and unfortunately a new worry. Trying to see how worried I should be.
    Just recently started getting a mild grinding (or perhaps chittering) sound when accelerating at low speed. Seems to disappear at higher speeds. Hoping perhaps a problem with sticking brakes or something that *might* not be too worrying.
    But exactly once, had it at a time that brakes made no sense. I was at a stop light, the car was in gear, but I had the brake depressed (because red light). And it was doing the same grinding sound. I switched the car to N, and the sound stopped. Put it back into D and it was chittering again.
    But only at that one stop, not any other time I've stopped. So I'm kind of confused.
    Trying to figure out possible issues, while trying to earn enough money to make it in to the dealership and get things checked over.
    52,912
    can you get a recording? did it start right after the new tires?
  3. Jon Batchelor
    35
    FL
    No, it started very recently, within the last week, the tires were about the second week of June, the new blower motor was about the third week of June. The grinding sound only started within the last 4 or 5 days. A recording? I might be able to try, don't know how well my phone would do on recording it, though.
    52,912
    how many miles on her?
  5. Jon Batchelor
    35
    FL
    325k miles, roughly.
  6. Jon Batchelor
    35
    FL
    OK, tried to record it, but you just can't hear anything. The phone just isn't a good enough recording device.
  7. PriusV17
    PriusV17 Active Member
    440
    207
    CA
    2017 Prius v wagon
    Could be failing wheel bearings. Best to try to find out which wheel the sound is coming from or just have the dealer or mechanic test drive it.
  8. bisco
    52,912
    not when stopped. must be something that runs without the car moving, like a pump, or ventilation system
  9. Brian1954
    Brian1954 Senior Member
    2,694
    1,077
    South Central PA, USA
