Light water damage -- car really unsalvageable?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by brka-brkb, Aug 13, 2025.
  1. pasadena_commut
    pasadena_commut Senior Member
    3,069
    956
    Southern California
    Really, 23 mOhm is a lot for a battery. The battery tester I have only works properly when attached right at the battery terminals (or metal immediately adjacent.) It does not work well at the jump point. The voltage is read properly at the jump point but the SOH is much much lower there than at the battery.
  2. brka-brkb
    brka-brkb New Member
    New York
    I made sure that both clamps on + and - were tightened so that they won't wiggle -- what else could I do to ensure that the connection isn't bad? Thank you!
  3. ChapmanF
    19,041
    What that information clearly states is how to triage flood-exposed vehicles into different severity levels, from least severe (level 1, water up to lower edge of rim/wheel) to most severe (level 5, up to top edge of dash panel). You find that table on pages 5 through 7.
    That requires "continue to step 2" under Vehicle Safing on page 4, and in table 1 it comes out Level 3. The things that should be inspected are what's listed for level 1, level 2, and level 3.
    A lot of the electrical wiring is under the carpet.
    The bulletin does say that salt water is much more damaging than fresh. If only fresh water was involved, the repair/replacement guidelines are a lot simpler.
    PriusCamper and Brian1954 like this.
