Lighted Console Box!
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Bob K., Jan 24, 2012.
  1. Bob K.
    Bob K. New Member
    23
    Baltimore, MD
    I bought a small little LED rechargable flashlight from Home Depot (about 1 1/2 inches long maybe). It shines a blue LED showing when charging. The problem was that it was way too bright! It was a pain!
    So, I put it inside of the console box so not to be seen so much. This is now great! When I open the lid at night it glows blue inside and I can see at night. If I crack it open (pull lid back a bit) it lights up the cup holder!
    Plus, if I need it, I pull it out for a bright white rechargable LED flashlight. This turned out super, and wanted to pass this along.:D
  2. ockevin
    ockevin Active Member
    493
    148
    Orange County
    Post a pic please
  3. cap160
    cap160 Older Member
    78
    Michigan
    Yeah, this does sound interesting! We need a little better description of the Home Depot Flashlight, maybe a name and a part number or Hom eDepot number, just where did you mount this in the box?
    Thanks
  4. cap160
    cap160 Older Member
    78
    Michigan
    I like to see if this idea would work in that godawful nether region under the console bridge!:mad2:
  5. bisco
    52,858
    i got one at an electronics store with a 3" gooseneck and spring clamp. i would also like to know how and where you mounted it so i can try to mount this one. thanks!
  6. Bob K.
    Bob K. New Member
    23
    Baltimore, MD
    Here are a few pics.
  7. phoenixgreg
    phoenixgreg Senior member
    1,157
    295
    66
    Phoenix
    I took a more difficult route for an OEM look. Mine has a hidden switch that brings on the lamp when the lid is opened. It was a major project though involving finding an "aways hot" lead behind the dash. The console lamp works whether the car is on or not.
    PriusChat Forums - phoenixgreg's Album: Center console light
    I also lit up the main cup holder and low bridge console with green LEDs. A very handy mod.
  8. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    I did that by mounting a low power blue LED under the bridge. Looks and works great.
  9. frodoz737
    frodoz737 Top Wrench
    4,805
    2,561
    33
    On the next list. Did you post details for this?
  10. phoenixgreg
    1,157
    295
    66
    Phoenix
  11. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Referring to me? If so, no I didn't write that up. Simply disassembled the bridge from above, drilled and mounted the LED (from radioshack) and tied it into the dimming trigger wire of the HU. I will post a pic.
  12. frodoz737
    4,805
    2,561
    33
    Thanks to both. Question was to Spiderman, but I take info from all parties before deciding. My original thought was to add the same lamp assy used in the overhead for shifter illumination, and tie it into the same circuit. That way it is only on with headlights (night) and same equipment. Toyota lamp assy probably cost to much though, so cheaper LED likely best with similar intensity.
  13. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Attached is a really quick write up on my under console light. Sorry for the thread highjack.
